02-15-2013, 04:33 PM | #1 |
high hump or low hump
I have a 1972 chevy c-20 pickup that iam getting ready to buy carpet for on lmctruck.com . But I don't know if its a low hump or high hump wondering if someone could help me out. The lmc catalog says to measure from the top to floor board if its 4'' then its low if its 6'' then its high. I measured 4'' but it use to have a standard in it which is now not in the truck its been switched over to a automatic. the reason I ask is a buddy of mine said that all standards are high hump ones but like I said I measured 4''
Any help would be great
1972 Chevy C20 Pickup 1974 Plymouth Roadrunner 2009 GMC Sierra 2011 Chevy Equinox |
02-15-2013, 04:39 PM | #2 |
Re: high hump or low hump
another question I have is the one with gas tank in cab cost 599 for the whole interior kit. but the one that says without gas tank cost 549. I know mine has a gas tank in it but I was wondering if I could cut the carpet when it get to the gas tank.
W/In cab tank carpet stops at front edge of gas tank W/out Carpet goes to back wall of cab
02-15-2013, 04:40 PM | #3 |
the high hump is bolted in and the low hump is molded in, three speeds and turbo 350s had low humps, 4 spds and turbo 400s had high humps
02-15-2013, 04:42 PM | #4 |
mine is bolted in. so its a high hump correct? sorry if I sound stupid but I don't want to order the wrong stuff. thanks
02-15-2013, 04:43 PM | #5 |
mt 69 cst had a turbo 400 and a low hump but your right about high humps being bolted in and low hump is molded in.
02-15-2013, 04:46 PM | #6 |
Thanks guys never mind about the carpet gas tank question they are both $599 so I will just order the right one thanks again guys
02-15-2013, 04:49 PM | #7 |
has anyone put these kits in before? will I need spray adhesive or should the carpet fit nice without sticking it down
and what did you guys use for underlayment for carpet
02-15-2013, 04:55 PM | #8 |
02-15-2013, 04:55 PM | #9 |
you shouldnt need glue they stay down good and the plate by the door opening will screw down over the edge of the carpet to hold down.
02-15-2013, 04:55 PM | #10 |
If it's bolted, it's a high hump. Also, my TH400 with 2WD has a low hump.
Not the question you asked, but I've seen where a number of forum members have said they weren't pleased with the LMC carpet. I used ACC carpet, and found the best price at www.rockauto.com. ACC is also sold by www.stockinteriors.com. I was very satisfied with the ACC 80/20 loop carpet with mass backing. I paid nowhere near $550. More like $200. I got the carpet for the in-cab tank and it fit right up to the bottom of the tank. NOTE: Be sure you order the right set. I don't see any at LMC for a pickup that approaches $550. |
02-15-2013, 05:04 PM | #11 |
that's the price for the whole interior kit comes with carpet, plastic dash pad cover, door panels, padded armrest set, vinyl bench set reupholstery kit for $599.
this is the pad I was thinking about going with http://www.lmctruck.com/icatalog/cb/full.aspx?Page=105 the one in the middle
02-15-2013, 05:23 PM | #12 | |
