02-15-2013, 07:23 PM | #1 |
fuel issue
in my 64 i have the behind seat tank still. po put in 72 dash, meaning a 90 ohm gauge. as you know my tank sending unit is 30ohm. does anyone make a 90ohm in the cab mounted tank sending unit? im tired of topping off every time i drive to make sure i dont run out if gas
Posted via Mobile Device |
02-15-2013, 07:43 PM | #2 |
Re: fuel issue
This might work : GM Fuel sending unit conversion 30 ohm
http://www.hotrodders.com/forum/gm-f...hm-106069.html |
02-15-2013, 11:43 PM | #3 |
Re: fuel issue
thanks but thats the opposite of what im looking for. ive found several things on if you have a 90 sending unit making it work on a 30 gauge. i have the exact opposite problem. i need a 90 sending unit that will fit behind the seat of my 64, so it will match my 90 fuel gauge from a 72
02-16-2013, 12:23 PM | #4 | |
Re: fuel issue
Hth, sam |
02-16-2013, 02:59 PM | #5 |
Re: fuel issue
im beginning to think my easiest option is to just get an autometer 30ohm fuel gauge. just really wanted to keep the old guages
02-16-2013, 03:12 PM | #6 | |
Re: fuel issue
And, if you're lucky, maybe the '67 send unit is a simple bolt-in. Look at both at a parts house & compare? sam |
02-16-2013, 03:51 PM | #7 |
Re: fuel issue
Maybe this can work, Adjustable 6-24" Fuel Tank Sender 0-90 Ohm
http://www.gearheadworld.com/store/C...-P7991C87.aspx http://67-72chevytrucks.com/vboard/s...d.php?t=288717 |
