Old 02-15-2013, 08:48 PM   #1
yellow400ex05
Question how do you turn on the interior light??? 66 C10
I was wondering how exactly do you turn the interior light on in a 1966 Chevy C10? which way do i spin the knob for the lights?
yellow400ex05 is offline   Reply With Quote
Old 02-15-2013, 08:54 PM   #2
jayoldschool
Moderator
Re: how do you turn on the interior light??? 66 C10
Good question. I haven't tried the light yet in my 65. However, if it's like my other classic GM cars, you grab the headlight knob and turn it counter clockwise. Keep us posted (although one of the vets will have the answer). Is it supposed to come on when one opens the doors?
jayoldschool is offline   Reply With Quote
Old 02-15-2013, 08:57 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
My 64 does not have door switches for the dome light. I am not sure if that was an option or not.
TBONE1964 is offline   Reply With Quote
Old 02-15-2013, 09:20 PM   #4
yellow400ex05
how much do you have to twist it for it to turn on??
Old 02-15-2013, 11:25 PM   #5
Idaho64GMC
as far to the left as it will go, on mine you can feel it engage. turn it back to the right to shut it off and increase brightness on dash lights
Idaho64GMC is offline   Reply With Quote
Old 02-15-2013, 11:54 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
If it doesn't work at all, it could be the contact point is worn/broken on the headlight switch, the ground wire coming from the dome light isn't connected to the tab on the headlight switch frame, the bulb is burned out, or a fuse is blown. The dome light is supplied with constant power. Unlike any other automotive circuit I can think of, operation of the light is controlled by the ground side of the circuit at the headlight switch.
Adding door switches is a simple matter of drilling/mounting the switches and tapping into the ground circuit.
Here's an excellent link showing how to add them:
http://www.persh.org/pickup/DomeLight.htm
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-15-2013, 11:56 PM   #7
MusicMan70
MusicMan70's Avatar
Yes it really works and operators are standing by...
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-16-2013, 12:02 AM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Old 02-16-2013, 01:03 AM   #9
Daze57
Daze57's Avatar
man!!!!!!!!!!!!!!!!!! dass messed up !
Daze57 is offline   Reply With Quote
