![]() Join Date: Dec 2012
3\5 springs
Am wanting to lower 70 step but am wondering if i can do it with just changing the springs its not a show truck but like the look dont want it on the ground but wanted to know if i needed to change spindles also ? Thanks to all
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 3\5 springs
You will also need drop shocks,... with your 3/5 spring drop.
Re: 3\5 springs
You can get away with just springs. Might not be the best ride but it will do.
Posted via Mobile Device |
Re: 3\5 springs
With 3" drop springs in the front, your LCAs will be dangerously close to the ground. IMHO
![]() ![]() It ain't yours, if you didn't build it! Last edited by lolife99; 02-17-2013 at 11:55 AM. |
Re: 3\5 springs
They will be 4.5"-5.5" from the ground without drop spindles.
Re: 3\5 springs
Lolife,
Won't the 3" springs put the lca's below the scrubline?
![]() ![]() It ain't yours, if you didn't build it! |
Re: 3\5 springs
Not by themselves.
My 69 has 3" springs and drop spindles. I plan to add 20" wheels,...
Re: 3\5 springs
just picked up a complete crossmember from a mid 80s truck and am going to rebuild it so am i correct to understand that i need to add drop spindles and does any one have pics of a truck with that setup? would like to see the finished product
Re: 3\5 springs
oh yeh and if i add new spindles can i still use my old arms ?
Re: 3\5 springs
Does anybody know if lowering springs have less coils (factory cut) or just made differently to lower a truck with same amount of coils? And if factory lowered springs are just less coils and are shorter, do they rattle around in spring pocket when truck is raised off ground for service?
