Old 02-15-2013, 09:20 PM   #1
57rookie
black smoke at start up
I have a very stock 86 GMC with the 305 and the 4 bbl quadrajet factory carb. It has a full tune up as I am restoring it and have put new plugs/wires,ect. on and it runs very well and idles well when warmed up but at start up it is choking its self and blowing black smoke out. I have heard that this is because my secondaries on the quadrajet are probably out of adjustment and are completely shut choking the engine of air. I don't know how to adjust this on a carburator, does anyone have tech info or pics to show me where I would adjust this. The truck runs so well once the electric choke finally seems to take hold but the black smoke and chugging at start up is very frustrating. Engine has only 60,000 original miles.
Thanks to anyone that can help.
57rookie is offline   Reply With Quote
Old 02-15-2013, 09:52 PM   #2
geezer#99
geezer#99's Avatar
Re: black smoke at start up
THe secondaries have nothing to do with it. You need to adjust the amount of opening the choke blade has. Yours is closed too much.
Here's a link how to adjust it open more on page 4.
http://www.vetteprojects.com/kstyer/quadrajet_4.htm
Old 02-15-2013, 10:36 PM   #3
57rookie
That's fantastic. It sounds like I need to turn the screw counter clockwise. I really appreciate this. I am not even sure I have a QJet, I assumed that all GM's in this vintage do but I get I better confirm this tomorrow when I try it. I hope it does not have a Carter otherwise I will not know how to adjust.
Old 02-15-2013, 10:46 PM   #4
geezer#99
geezer#99's Avatar
If you have a problem take a pic so it's easier for us to help. All carbs are adjustable. Each is different.
Old 02-15-2013, 11:00 PM   #5
57rookie
thanks again. I will hit the garage tomorrow and see what damage I can do. It runs so smooth and strong and I did the full tune up on it last week and the carb functions very well, just loads up and floads at start up so hopefully I can adjust the plate open more to fix it. I will report back in and thank you for taking the time to help.
Old 02-16-2013, 12:05 AM   #6
meatwagon83
meatwagon83's Avatar
black is fuel your a little rich
meatwagon83 is offline   Reply With Quote
Old 02-16-2013, 12:34 AM   #7
mrolds88
Not sure what screw you are talking about. What you need to do is adjust the round black piece on the passenger side front of the carb. Some of them came with the three holdowns riveted on. Thats a simple drill and tap operation. When you do get everything loose and adjustable, set it cold to about 3/16" pen. Still gives you air and pulls enough fuel when cold. Thats exactly what iI did when I had my 86.
mrolds88 is offline   Reply With Quote
Old 02-16-2013, 11:22 AM   #8
geezer#99
geezer#99's Avatar
Open up the link and you'll see what screw he's talking about. If his carb has that screw then he won't need to adjust the cap.
