Two or four row radiator
I'm tired of fixing holes in my rad, fixed the upper hose neck a few days ago and today another pair of holes showed up. Should I get a two or four row rad? I have a 72 GMC 4X4, 350/350. I tow a small teardrop camper in the summer, going up hills it would warm up but I can't remember it ever overheating but if I'm going to get a new one I'm thinking I should just get a four row. Any suggestions on what and where to buy? Thanks!
http://smg.photobucket.com/albums/v655/aaronhero/ |
Cluster King
![]() Join Date: Nov 2012
Re: Two or four row radiator
What does it have now? If it is a two row and you go with a 4 row then you will need the upper brackets. They are wider for a 4 row. Also it is going to place your fan shroud a little closer to your fan but that should not be an issue.
The 4 row is going to be a bit more pricey but I think it is good piece of mind, especially if you are towing anything. |
Check out Champion Radiators,they are owned by Led Foot Racing.I just bought a two row for 209.00 shipped to my door.Very happy with it.
84 step side 87 swb |
#4 | |
I don't want to buy a two row and regret it later, I don't mind spending a little extra now if its going to be a big improvement in the summer, I drive a lot of steep mountain roads. Now that I think about it my truck has got pretty hot climbing long hills in the summer, not to overheating but I find myself watching the gauge a lot and it would be nice having more cooling. It's got to better for the engine and trans.
http://www.oreillyauto.com/site/c/se...yword=radiator
I had one shipped last year and it was around 200 and change. If you go with 4 like mentioned above the brackets and fan shrould will be an issue. They are copper and not plastic btw. |
I am a Referee of life.
I put a 4 row in mine and I'm running a 250/6.I figure it's good insurance and I've never heard anyone say"My truck runs too cool".It seems like it heats as quick as the 2 row that came out and had some bad tubes so I guess it's not running too cool.Actually the thermostat should control the temp.It took maybe 30 min to swap in 4 row mounts and the rad was all copper/brass construction.I gave right at $200 for it at O'Rielly's.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
What do you guys think of this? Or should I spend another hundred and go for an aluminum radiator? Does an alumunum radiator cool bettery/last longer?
http://www.oreillyauto.com/site/c/de....oap?year=1972
Old member
4x4 towing a trailer + steep hill's = 4 row hands down, no questions asked!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I posted one from Orielys above, what do you think?
Old member
I would go for it. Sounds fine to me. The all aluminum ones aren't that much of a bargin for a street truck. Unless your talking a BB motor with mods then it maybe worth it.
#12 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
#13 | |
#14 |
Thanks guys! I appreciate the advice!
#15 |
Old member
Your welcome anytime. Don't beat the heck out of it before you have the new one in and running though!
#16 |
My 4 row came out of a junk yard 25 years ago. Dad had bbc and sbc in it with it, and never tried over heating. Now, with the built 355 Noo matter how mean I am to it it'll stay at 160-170 then once I stop say in a parking lot and leave it on for a few, it may reach to right at 180
Posted via Mobile Device |
#17 |
I recently bought one from Autozone and appears to be a 4. I know I had to get 4 core radiator brackets to mount the bugger. I don't know if it is the same for a 4x4.
My Autozone by me had it in stock for $184.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
#18 | |
#19 | |
Was yours the same? |
#20 |
Yeah, I had to make two cuts and bend the lip on the support out of the way. I probably could have thought of a prettier way to do it, but it worked.
#21 |
I'm hoping my brackets are for a four row radiator, they are to long for the radiator in my truck now. I can push the top of the radiator back about an inch and a half. I have a shallower shroud if mine is too deep with the new radiator. While looking for that shroud I found two other radiators I had stashed in my basement, they're only two row radiators and somehow a squirrel filled the tanks with acorns, along with my MIG welder. My wife just called me to tell me my son inlaw picked up my new radiator, he even paid for it! He keeps doing stuff like that to keep me in debt to him and earn points, too bad I wasn't having my wife pick up a new aftermarket AC system for my truck, it would save me a thousand bucks!
#22 |
Watch when you install.I forgot to mention it before but my fan was too close to the 4 row,so I had to change the fan spacer.Cost me an extra $7 whole bucks.
#23 | |
#24 |
Got my new radiator in this morning, fit like a glove! I have about six inches of clearance between the front of the fan to the radiator, my shroud actually covers the entire fan now, before it only covered about half of it.
The new four row radiator has an extra bung right below the cap and near the upper trans cooler line, it has a plug in it, any idea what it's for? Thanks again for all the help guys! Posted via Mobile Device
#25 | |
![]() Quote:
sam |
