drive shaft
A two piece drive shaft is stronger than a one piece, but is the mid carrier the weak link. how much abuse can a stock one take on 345 rear wheel hp and sticky tires.
#2 | ||
"I ain't nobody, dork."
Re: drive shaft
I have a bud that owns a 1960 Impala drag car. He is putting 850hp through that rig, and it has a stock 2 piece driveline with larger u-joint yokes welded on it. It has a factory GM carrier bearing in it. It has yet to fail wuith countless 1/4 mile passes on it.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: drive shaft
That depends on which carrier bearing you use. The light duty one that hangs from the top of the T/A crossmember or the HD one that sits on the bottom of the T/A crossmember. Of course this is assuming you are talking about a '60-'72 truck.
#4 | |
Re: drive shaft
Re: drive shaft
1970 and has the one that hangs from the top.
60-66 Nut
Re: drive shaft
Personally I would not run those driveshafts and carrier bearing behind anything other than a stock 250 I6. With the amount of HP you are putting down, I would definitely upgrade to the HD carrier bearing and driveshafts. Just my .02
#7 | ||
Re: drive shaft
The driveline I told you about might not even be compareable to a truck drivline. Just thought it was amazing myself that a relatively stock 2 piece with a carrier bearing was workin' that much HP and TQ.
Didn't wanna give out any false hope or bad info. ![]() Gary
#8 | |
Re: drive shaft
what I have listed above is whats on the truck, 1/2 ton and 3/4 so it says. |
Re: drive shaft
Do not worry Gary I know what ya sayin.
#10 | |
60-66 Nut
Re: drive shaft
That's the whimpy one. I have never seen one of those on a C20 truck. Those are the carrier bearings that give 2 piece driveshafts a bad reputation.
The HD carrier bearing is the one shown over on the right side of the page. Quote:
the boat guy
Re: drive shaft
We build stock car driveshafts out of the same tube and weld yokes that came in these trucks, they handle 500hp+ in race conditions. Did I mention we drill a 1.5" hole in the center of the weld yoke?
The weak link is the stub with the bolt on yoke. If your running an auto without a trans brake or slicks I wouldn't worry about it. The carrier bearing can handle 2000hp it just spins, it might take 2in/lbs to spin. Why these carriers fail all of the time is that the shafts need to be reballanced after they have been worked on. Even something as simple as changing a ujoint will cause enough of a vibration to cause the carrier bracket to fail. Much less putting the bolt on yoke not in time, or putting the rear shaft in 180* out of time or even puttng the rear shaft in backwards. Good ujoints and a ballance and it should last 100k miles. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Re: drive shaft
Brad man 72.
Thank you very much for the information. I have heard about this being a good set up. tubing wall 0.090 thick I was told before. I often had thoughts that the carrier was just there for the ride and maybe move a little with pinion angle set up and launches. Like Gary said on post up top, can hold tremendous amounts of thrashing. I do run street slicks on it. 1310 u joints. 4:10 gears should help a little on the shock factor do ya think. |
#13 |
the boat guy
Re: drive shaft
Its either .120 or .083 wall, I can't recall (been violently ill all day)
If everything is in good shape you should be fine. Some people do like to weld small brackets to thicken up the sides of the bracket for some insurance. I wouldn't worry about your setup at all with street tires and your power. If you're worried about it at all have a driveline shop install some spicer life joints (solid cross, non greasable) and have them ballance the shaft. (Good insurance for any car) Posted via Mobile Device
#14 | |
Re: drive shaft
#15 |
Re: drive shaft
Sorry. Disregard.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-19-2013 at 03:35 PM. |
