OK Metal wizzards lets see what what you have ! 47-59 Cool body mods Suttle to Wild kustom touches
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
![]() Join Date: Mar 2007
Re: 47-59 Cool body mods
I'll start......nothing major just added some louvers and smoothed my cowl panel and went with a different latch.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
A 3" chop on a small window but keeping the window opening the original size making it a "medium window?"
![]() ![]() Join Date: Nov 2008
Young Rodder,
Your truck is flat gorgeous. Whose color is that again? I LOVE the detail & finish on your truck. Posted via Mobile Device Last edited by Dan in Pasadena; 02-16-2013 at 11:53 PM. |
#5 | |
![]() Quote:
You know that imitation is the sincerest form of flattery. Loved the louver idea the first time I saw your truck! Speedbump Nice chop I don't know if I've seen cleaner lines The burb has frenched headlights. smooth hood & running boards. 51 doors w/vent windows .Fooseed bumpers ,59 Caddy tail lights & molded rear fenders (not recommended,looks good but can be problematic) ![]()
Young Rodder,
Your truck is flat gorgeous. i agree! |
Nice Burb. I almost did the molded rear fender to get rid of the bolts in the bed but woosed out and used polished stainless buttonheads instead. So....
what's the problematic part? Cracking is what my thinking was when I decided against with no past info. |
Youngrodder, every time I see photos of your truck more nifty little details come out that I missed previously. That truck is a true lesson in the concept that attention to details no matter how small they seem to be really counts and adds up in the total truck.
#9 | |
Thank you Thanks.One of the lessons I learned in a college design class that has always stuck with me is less is more. I think that really applies to hot rods..
Youngrodder, I noticed your bumpers are shaved. I plan on doing the same with the bumpers for my 52 chev 3100. My question is did you weld the bumper bolt from the back side of the bumper and then fill in the head when ground? and do they still bolt to the original brackets?
Joe |
#11 | |
Joe-- Good eye... That is how you would do it. I started out that route then I found this bumper at a car show for sale. It is made out of SS and it mounts to the factory brackets. My build was very long and I don't recall the name of the place that I bought my bumper from. Marc
#12 | |
No cracking even when the F@#d 9 " rear bearings let loose at 75 mph !! The axel slid out & cut the white out of the white walls ! With the static drop you have to raise the truck & loosen the shackles. But the look is smooooth.
#13 |
every panel has been modified to some degree on truk
subtle: shaved: cowl vent, firewall, door handles, filler neck, trim, antenna wild: bed, interior, airbrushed trim, remote filler door ![]() ![]() ![]() ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#14 |
ogre
your truck is a gorgeous machine - detail is great !!!! |
#15 |
ogre
Very nice I love the subtle mods that make you go Humm !
#16 |
Nice! I like the stainless fasteners you used? If I can ask a question, what size are the bolts you used on the cowl? Would you happen to know the size of bolts that hold on the fenders, running boards etc? Mine are a assortment of too small or none at all. Thanks!
#17 | |
The bolt size really varies by location. My running board supports are not stock and the bolts are specific for my set up. The bolts for the cowl are stock size (it escapes my at the moment what the size is). I just went to Fastnal and ordered a bag of various sizes of button head SS bolts, washers and nuts for what I needed. I hope this helps. Marc
#18 |
Google "rod and custom dream truck" and click on images to see lots of custom ADs
#19 |
Stake pockets removed....... very subtle........
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
#20 |
I like the look of the rounded bed rail end on Kabwe's build. It really ties the end of the bed rail together nicely
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#21 |
I do too but it's more "custom" than my truck will ever be. I plan to cap the beds ends. Mar-K sells the caps pre made for $15 so I'm going that way. Still can't decide on using stock chains or not. I like the old timey-ness of them but they ultimately end up chipping paint.
Posted via Mobile Device |
#22 |
dan
put the chain in clear plastic hose - i am sure you can find it @ a hardware store and cut to fit ' |
#23 |
![]() Join Date: Jun 2011
Big Bertha has so much metal surgery that she is pretty much all custom.... I cant think of one panel that has not been re-configured.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
#24 | |
Oh and Buggy, that truck kicks an immense amount of ass.
#25 |
Addicted to Rust
![]() Join Date: Dec 2009
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
