02-16-2013, 09:38 AM | #1 |
Power steering Mod.
I did a power steering conversion on my 1969 Blazer. Everting bolted up nicely and fit like a glove. However to to get my rag joint to fit and to get my pttman arm bolted so everything lined up my steering wheel is not centered it is 90 degrees out with everything else straight. Can I just reclock my steering wheel?
02-16-2013, 12:16 PM | #2 |
Re: Power steering Mod.
If the alignment is good, you can just reclock the steering wheel.
02-16-2013, 12:20 PM | #3 |
My 72 has an adjustable link between the pitman arm and the knuckle. I turn the wheels to the farthest point in both directions and make sure this is equal. and then clock the wheel and then fine tune with the link.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-17-2013, 09:53 AM | #4 |
I reclock the steering wheel once and drove the truck. It was still off to the left a little and I reclocked it again but I haven't driven it yet. I dont have a adjustable link to dial it in.
