Old 02-16-2013, 04:13 PM   #1
JGross
1965 Temp Sensor Question
I'm putting a 5.3L in my 65 C10, you guys that have done a similar swap what did you do with the temp sensor? My sensor is over 3/4 of an inch and I don't think there's enough room to drill and tap the head.
JGross is offline   Reply With Quote
Old 02-16-2013, 04:39 PM   #2
71chevystep4x4
71chevystep4x4's Avatar
Re: 1965 Temp Sensor Question
You dont have to drill and tap anything. Theres a alan plug behind the passenger side rear exhaust port on the head, just remove it and get Auto Meter #2277, which is an adapter, then the temp sender for that (dont have the part # on hand).
71chevystep4x4 is offline   Reply With Quote
Old 02-16-2013, 04:42 PM   #3
71chevystep4x4
Auto Meter temp sender #2259
Old 02-16-2013, 05:11 PM   #4
JGross
Will this work with the original temp gauge?
Old 02-16-2013, 06:15 PM   #5
71chevystep4x4
yes
Old 02-16-2013, 11:06 PM   #6
TR65
TR65's Avatar
Hey guys,
There are a couple of issues here. The port on the LS heads is metric not 1/8" pipe. 65 trucks use a lower resistance sender than the later models. See the attached data.
I have been trying for some time to get a sender that will work with the original gauge. No luck yet.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 02-16-2013, 11:52 PM   #7
71chevystep4x4
Yes the port is metric, which is why you use the adapter first stated #2277, which you then install the sender #2259 into. Resistance wise, I do not know, just everyone else is running that combo as am I.
Old 02-17-2013, 11:13 AM   #8
TR65
TR65's Avatar
71 Chevy,
I think the 71 OE used the late model sensor. I think they changed in 67 maybe? JGross has a 65.
TR
1965 C10 SWB Fleet
Two owner
Old 02-17-2013, 01:24 PM   #9
ls1nova71
ls1nova71's Avatar
Originally Posted by TR65 View Post
71 Chevy,
TR
Are you saying that a 65 uses a bigger sender than a 67-72? My 71 uses a sender that's almost 3/4 inch and there's enough room to drill and tap the head. There's pics in my build thread of my 71 in my sig that show exactly what I did.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-18-2013, 12:26 AM   #10
TR65
TR65's Avatar
LS1,
I think drilling and tapping the head is a good way to go and solves the problem. I just want to avoid that if I can, don't want to pull the engine back out. The 65 sender is the same 1/2" NPT as yours.
What I don't know is what year they changed the resistance to the higher value.
TR
1965 C10 SWB Fleet
Two owner
Old 02-18-2013, 04:45 PM   #11
solidaxel
solidaxel's Avatar
I just found a nut to fit the plug in the pass. head and it is a 12M X 1.5.
Did I read on here that someone took the stock 70's sending unit and turned it down to a 12 X 1.5 thread?
Is there enough meat left on the stock sending unit to do that?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
