Old 02-16-2013, 06:08 PM   #1
wxman1
Brake Line and Prop Valve Plumbing
Have finished the rotors and caliphers on my 69 C-10 P/U truck upgrade.
Have installed a disc brake M/C and a proportioning valve. Below is a pix of the valve. It shows 2 ports for the front and a large one for the rear. Do I need to run 2 lines to the front(one for left and one for right)? The dealer said some people plug one of the front ports and run the front disc brakes off the one remaining port.
Has anybody actually used this particular this prop valve before? Did you run 2 separate line on the front or just one?
Jim
wxman1 is offline   Reply With Quote
Old 02-16-2013, 06:23 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Brake Line and Prop Valve Plumbing
I mounted my prop valve in the frame and ran 2 seperate lines for the front.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-16-2013, 06:24 PM   #3
68streetrod
I just did my brake lines last weekend and added the front disc on my 68 and used the same valve.
I ran the 2 front lines one from each port on the valve. I have seen where some have blocked off one port and used a spliter to both fronts but i'd rather have 2 off the valve.
Haven't got to try them out as i'm still in final stage of build but should be ready to go by spring.
68streetrod is offline   Reply With Quote
