Old 02-16-2013, 07:12 PM   #1
AirSpeed
AirSpeed's Avatar
Transmission lines with cooler
Getting ready to install a new radiator and got to looking at my tranny lines, they're a mess. The PO did a hack job on them, they've got to be replaced. Should I run hard lines to everything or is it cool to use hose from the end of the line to the cooler and back to the radiator? What is the correct flow, I mean which line goes to the cooler and which goes directly to the radiator? I dont trust anything the po did and dont want to go off his work. Should I make my own lines or just order a set? I have a tubing bender but no flare tool. If I can buy a flare tool and tubing for the same or cheaper price than buying premade lines I wouldn't mind doing it myself. Any tips or suggestions would be greatly appreciated!
AirSpeed is offline   Reply With Quote
Old 02-16-2013, 07:55 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Transmission lines with cooler
This diagram is the correct way to route the lines on all automatics except the 2004r. The lines are reversed on that transmission as far as output and input.
You will need to run some sort of flex line between the engine and radiator/cooler lines due to the engine movement. This can be trans oil hose with clamps or SS lines.
Notice that the hot line on the bottom trans fitting goes to the bottom fitting on the radiator, up through the radiator cooler and on to the bottom of the trans cooler then out the top of the trans cooler and then back to the top fitting on the trans.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-16-2013, 07:59 PM   #3
AirSpeed
AirSpeed's Avatar
Notice that the hot line on the bottom trans fitting goes to the bottom fitting on the radiator, up through the radiator cooler and on to the bottom of the trans cooler then out the top of the trans cooler and then back to the top fitting on the trans.[/QUOTE]
Thank you! That helps a lot! Any opinion on premade or home made lines?
Old 02-16-2013, 08:11 PM   #4
DesertCat
DesertCat's Avatar
I have always bent my own hardline and been very happy. You can get it at your local auto parts store pre-flared if you want and just get a simple tubing bender.
Never needed any flex lines nor seen that from the factory either IIRC, never had a failure but maybe I'm just lucky.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 02-16-2013, 08:18 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
If it were me, I would hard line as much as possible. Get yourself a nice flaring tool. I would just use steel line that can be bought at Napa or other parts stores. If I am correct, 60 inches is the longest piece you can buy and that should be just long enough with bends to go from the trans to the radiator for one line. You can buy shorter lengths of it for the rest. The line is 5/16 and it will have the correct fittings to thread into the trans and the radiator.You could use stainless but it is a pita to bend and flare and you have to be dead on with the flare or you will get leaks.
You will have to use some rubber at the cooler because of the way it is designed. I would not use over 6 inches of rubber hose.
Take your time and this job will look fantastic. I love paying attention to the smallest details, they do get noticed.
TBONE1964 is offline   Reply With Quote
Old 02-16-2013, 08:21 PM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Re: Transmission lines with cooler
I ran steel lines up to the radiator but put rubber hose to it. The fittings were for that so I went with it. Nice diagram Vett.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-16-2013, 08:37 PM   #7
airdale94
airdale94's Avatar
You can get a OTC flare tool for $25.00 from Amazon. It just depends on how you want it. Pre-bent will look factory. Bend your-self will look as good as you can bend. Most of the older GM rear wheel drive don't have a rubber flex at the radiator. Alot of cars do though. Rubber is OK if just want to patch it up. Just make sure you tell them trans. hose. You may need double clamps if the lines aren't dimpled. If you're not proficient at bending you can get poly coated steel line, it's a breeze to bend. It's the dark green stuff.
Yes, great diagram Vette!
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 04-19-2013, 03:18 PM   #8
AirSpeed
AirSpeed's Avatar
I just got done replacing the cooler lines, went to NAPA and bought two preflared 60" lines and one 30". Bought a new tubing bender and a foot of hose. To replace everything including buying the new tube bender cost me $48, I ended up only using about 8" of hose because I was able to run the steel lines right up to the trans cooler. It was kinda fun bending the tubing, routing it around everything. I can't believe how easy it was and how fast it went, my bends turned out perfect which I'm choking up to pure luck! I started out really stressing about it then I just said screw it and got busy bending tubing. I did have to solder on some barbed brass fittings to the aux cooler, it had 3/8" tubing and there was no getting that high pressure hose to stretch over.
It was far cheaper than buying pre bent tubing! Thanks for the help guys!
Old 04-19-2013, 04:56 PM   #9
JointTech
JointTech's Avatar
that $25 tool from amazon doesnt work on steel line. Its worthless. In fact worse than worthless because you waste 5 hours and a few trips back to the store for more steel line.
If you are going to get a flaring tool dont spend less than $100 on it is the word on the street. I just ordered a Rigid for $125 or so. Hoepfully it actually works because it will be my 3rd this week. Amazon and Pepboys versions both failed miserably.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 04-19-2013, 05:12 PM   #10
eagleuh1
eagleuh1's Avatar
I made steel lines for everything, and used compression fittings with loktite on nuts for connecting to the aftermarket cooler, after cutting off the roled edge. So far no leaks after 20k miles, 3 years or so. Good luck, and another for the more expensive flaring tool.
eagleuh1 is offline   Reply With Quote
