Active Member
![]() Join Date: Nov 2012
How/what do you use to polish a stock 72 black steering wheel? It's in good shape with no major cracks and I don't want to repaint it.
67 C20 283/4 Speed |
![]() Join Date: Apr 2008
Re: How to polish stock steering wheel??
I use a fine rubbing compound to clean mine up- seems to work well
#3 | |
Active Member
It's probably not too rough,but if it doesn't give the results you want you just move on to a finer polish. It can't hurt. The more coarse compound will make quicker work of the worse areas. I use that Nevrdull for final polish. It's cloth with polish in it and comes in a dark blue tin can
www.nevrdull.com
I used a high speed polisher that I use to buff my paint with the same 3 step polishing compounds I used on my truck. 3M foam pad 3M compounds
Fuzzy |
#6 | |
Active Member
MCGUIRES has a product for cleaning and polishing plastic type stuff PLASTIX i use it on a whole bunch of things very easy to use and handbuff friendly gives a nice clear bright shine to alot of things
#8 | |
Fuzzy |
PLASTIX on a foam pad on a drill, great for cleaing up music or game disc also, from not working to mirror smooth very quick.
Chevy GMC Trucks Find Of The Day https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com |
Parts and more parts
I would use a product such as the 3M Finnesse-it polish and if nothing else a good rag and hand rub it. The high speed may work, but since you are a novice it could burn the plastic and cause a distortion. I have two different polishers that I use. I have a Makita buffer that is variable speed and I also have a porter-cable buffer. They both have the adapter from 3M on them and can take numerous pads, form a wool bonnet to a soft foam pad.
Frank |
Active Member
Thanks everyone. I'll get some Plastix to try tomorrow.
