Driveshaft safety loop
Ok so I got the rear down (85 swb c10) and the driveshaft now hits the rear crossmember (the one under the bed, second row of bed bolts) I planned to raise it some then I remembered I had a 1 1/2 tube U-bend laying around and would work perfect as a safety loop. All great till I realized my driveshaft is 7/8" offset to the pass side. (9 inch ford pinion is not centered)
So my question to you guys is, what should I do? Center the loop in the frame? Center the loop on driveshaft? Split the difference? Thanks ![]() ![]() ![]() ![]() Posted via Mobile Device |
![]() Join Date: Mar 2011
Re: Driveshaft safety loop
I would center it on the driveshaft. Looks good!
edit; Taking another look at it, seems you have enough clearance and I like where you have the ends mocked up. Unless you think it could make contact, that will work fine too.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 Last edited by DesertCat; 02-17-2013 at 04:24 AM. |
X2
NAME: TRAVIS TRUCK: BRUISER 71 C/10 SWB 3.5/5" drop 4.11 GEARS. F.A.S.T. BBC 408 496hp/479ft/lb JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530 |
I plan to cut the center out of the crossmember and the "loop" will extend through the crossmember and bridged on top an inch or so above the current Xmember.
Thats the plan. First I must get the motormounts and trans crossmember figured out. Thanks Posted via Mobile Device |
I would center on driveshaft...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
