Old 02-17-2013, 06:32 AM   #1
blazercrazy70
blazercrazy70's Avatar
Anybody know if u run a 295/40/20 tire on a wheel with 5.5bs if it will rub
going with 3/5 drop wanting to run 20x10 with 5.5bs mounting a 295/40 tire if it will miss the wheel well
blazercrazy70 is offline   Reply With Quote
Old 02-17-2013, 09:29 AM   #2
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: Anybody know if u run a 295/40/20 tire on a wheel with 5.5bs if it will rub
It will fit just fine, heres my old truck with 20x10 Coys with 5 1/2" backspace and 295/40/20's.
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 02-17-2013, 10:03 AM   #3
Expat_dude
Expat_dude's Avatar
What year model truck? I am going with the same size tire however the rear end on my 70 is a bit narrower. Travis suggested a 4.25 bs on my incoming Vintecs
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline   Reply With Quote
Old 02-17-2013, 05:50 PM   #4
skorpioskorpio
How high off the ground is your frame? and how much travel? I am going to be running 295/45/18s which are roughly the same size as your 20s, just less rim. I am also going to be running a *lot* of backspace (around 6.8" on a 10" rim) but plan to make it up in longer Porterbuilt control arms and a custom Moser rear. I should be even a little better in that the longer control arms will push the steering pivot a bit more into the wheel so the tire should do a little less forward and back movement. I'm starting with a 4WD Jimmy so drop number aren't going to really help me much, I'm more curious what the end result is. I am shooting for about 7-7.5" from frame to dirt and probably 3-4" of suspension travel seems to be what a 2" modular spindle and a DM Mild cross member will give me with 28" diameter tires.
The wheels I'm using are Superperformance Shelby Daytona Coupe wheels and the backspacing is net after the pin drive adapters:
skorpioskorpio is offline   Reply With Quote
Old 02-18-2013, 06:02 AM   #5
blazercrazy70
crawdadfox what is the wheel and tire size on the front and what is your drop..
Old 02-18-2013, 08:06 AM   #6
LakeAnna
LakeAnna's Avatar
I like your "old" truck bro! Is that a 4/6 drop?
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 02-18-2013, 09:15 AM   #7
CC69Rat
CC69Rat's Avatar
Assuming from your forum name - your truck is a 1970 model?
The reason I ask is there are two different axles in these trucks. In 1967 up through the end of 1969 and SOME 1970 model trucks (early production) the trucks had a 55.5" rear end housing in them. When I say 55.5" I am measuring from the inside of one backing plate to the other. This will just keep you from having to take the wheels off, you can lay under the truck and have a buddy / wife hold one end.
In 1970, they started changing them over to a longer rear housing. Using this same measurement the longer housing is 57". You really need to know which housing you have. Crawdad's truck is a 71-72 (can't tell.. 71 I think) so I am 85% sure the rear end housing is 57" wide. In his example, the 5.5" BS will work, and it's sweet as hell. This is one of my favorite trucks on the forum.
What if you have the 55.5" housing? That wheel would not sit the same. It would be tucked under the truck another .75" either side. IF you happen to find you have the more narrow axle (more desirable really) you can run a 5" BS on your wheels. This makes the wheel look wider (Some manufacturers will just use a thicker wheel flange and the wheel will actually look the same though)
Same size tire will be fine.. 5" on a narrow (55.5") housing, 5.5" on the later / wider (57") housing. The 5" BS wheel will offset this difference for you.
While not the end of the world if it's 1/2 off but 5.5" on a narrow housing truck would sit pretty far under the wheel well and I'm thinking would probably rub the inner bedsides. (never tried it personally) With a 70 model truck it's a roll of the dice. My 70 GMC has the longer housing but I have seen 70 with the shortie. Just sayin, you might want to check.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-18-2013, 11:00 AM   #8
crawdadfox
crawdadfox's Avatar
i had a 3" spindle 1" spring in front and a 2" spring and 2 1/2" block in back. Front was a 20x8 1/2" with a 255/40/20.
