Gauge Bulb Caps and Sockets
I climbed under my dash yesterday to check out the bulb situation on my gauge cluster and found that I have a couple missing bulb caps as well as a few sockets that don't light a good bulb. I'm guessing that the dead sockets are a problem with the circuit layer but does anybody know where to replace the caps that are missing and what portion of the cluster the caps actually fasten to? All my gauges work great, I'm just the type of person that wants everything working right, even if it's that minor. Thanks for any help, Troy
Posted via Mobile Device |
![]() Join Date: Oct 2012
Re: Gauge Bulb Caps and Sockets
The sockets are available at LMC, and the bulbs are available at any auto parts store, Walmart, etc.
Your best bet is to remove the cluster and check the printed circuit board to make sure It is in good shape. You'll have access to everything and be able to clean it all up in the process. New circuit boards are also available. Posted via Mobile Device |
C/10 junkie
I have a few of the sockets that you can have, how many do you need?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
You can get the socket & bulb as part number PC 194 at most any auto parts stores for about $2 bucks each. The last time I bought some I had to order them, it only takes a day or two.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
what he said
Fuzzy |
Thanks for the info everybody. I think I'll get what I need and make this my project for next weekend. I'm hoping that the ones that the sockets that won't latch in are just because the cap itself is worn out. Thanks Shawno for the offer of the caps, but if they come with the bulbs then I'm good.
C/10 junkie
No problem. Let me know if you change your mind.
BUMP.
Will these work on 73-87 trucks too? I need a few. IM |
i recommend these. i use them in every vehicle i have. The LED lights really help make the older gauges more visible. they'll work on the 60 - 98 GM dash clusters /6Pcs-White-PC194-T10-Instrument-Cluster-Led-Light-Bulb-Dash-Socket-For-Chevy-/231584199982?fits=Year%3A1972|Make%3AChevrolet&hash=item35eb7e752e&vxp=mtr"]
72 C/10, LWB, 5.7, Auto, with A/C ![]() F.B.I = Full Blood Indian Appalachia/Eastern Cherokee,"Tsalagi" |
![]() Join Date: Aug 2008
I had a similar problem with good lamps not working in several spots with an oem printed circuit and a repro pc on my 72 stepside. I noticed one of the clusters from a truck I parted out (68 or 69) had lamp holder that takes a lamp with brass base instead of the bayonet glass base. I swapped all of them over, old lamps and all, and they all came on. ??? The old cluster was missing a few so I had to scrounge around for teo more. I forget now who had them, but they did the trick.
![]() Join Date: Feb 2015
PC168 and PC194 sockets are too small for my 71 C10.
http://67-72chevytrucks.com/vboard/s...d.php?t=693490Cheyenne, AKA "Spare Change" Hack71 Build |
![]() Join Date: Apr 2016
Can you post pictures of a socket from your cluster that does fit, along side the new one that doesn't fit? And picture of the back of your cluster where you are trying to fit the bulb?
#13 |
Found the right socket at Napa part # LS6501.
I don't have a pic of the wrong one as I returned it. They look identical the wrong one was just a little smaller diameter.
