Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-17-2013, 02:59 PM   #1
ItsRandy
ItsRandy's Avatar
Converter question...
What does it mean when you guys talk about a converter "flashing"?
I thought I knew a lot of stuff when it comes to high performance cars/trucks but the more I read on these boards the more I realize I don't know anything.
Can you help a guy out?
ItsRandy is offline   Reply With Quote
Old 02-17-2013, 05:29 PM   #2
Super73
Super73's Avatar
Re: Converter question...
So, on the transbrake, my converter goes to 5,000 rpm.
If I leave off idle or 2,500 with the foot brake or 3,500 with the two-step, the converter flashes to 4,500. It never reaches the 5,000 it does on the t-brake.
Advertised stall speed and actual flash speed are rarely the same. Ideally, the stall speed and flash speed should be the same but rarely are.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-17-2013, 06:14 PM   #3
Blue Rat
The flash point is where the tranny engages an starts pulling. All this happen in just a fraction of a second.
Blue Rat is offline   Reply With Quote
Old 02-18-2013, 11:00 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
My new converter ( freakshow out of Abilene Tx ) is listed at 4000 rpm stall . If i take the 2 step off and dead head it , it is around 3900 rpm . If i 2 step it at 2200 it flashes to 4100 or 4200 when i release the transbrake ( happens quick and im trying to drive ) . If footbraking it will load up against the brakes up to about 2600 before it over comes the clamping force of the brakes and when i swap legs it flashes to 3700 or 3800 .
This converter will drive the truck around town just fine and is a touch "loose" on the bottom , but once it is above 2300 rpm it is seamless . The stall is not like a light switch . The rated stall is the point at which the converter starts becoming efficient . The flash stall , as i understand it , is when power is applied quickly were the converter "catches" the power . The "flash stall" will vary with your set up , weight vs power etc.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
