02-17-2013, 03:03 PM | #1 |
Temp sender help
Does anybody know what sender to use for the warning lights and were to find one. I have a mechanical water temp gauge but would like to get the stock lights working. Hope someone can help Tkanks Ray
02-17-2013, 04:09 PM | #2 |
Re: Temp sender help
You should still be able to find those at your local chain parts store. If the computer doesn't go back to 1966, just have him look in the later years until you find one. To my knowlege, they are all the same. you'll need to pay attention to the size of the bung but you can always use an adapter.
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
02-17-2013, 04:55 PM | #3 |
Thanks Hilandr451 so do you think the sender is the same for factory gague or warning light Thanks Ray
02-17-2013, 06:48 PM | #4 |
O'Rielly Auto Parts here, carries the two wire one under a Borg Warner part number WT356. If no O'Rielly's there, other stores should be able to cross that number
Autozone crosses it to a TU47 Last edited by tincan1966; 02-17-2013 at 06:58 PM. Reason: added info |
02-17-2013, 06:49 PM | #5 |
The above part number is for the light type that has a cold and hot light.
