![]() Join Date: May 2012
Porterbuilt older style hood hinge brackets?
I am looking for a set of these Porterbuilt hood hinge relocation brackets. I thought someone may have a set after upgrading to his newer style hood hinges. I posted here figuring guys may frequent this section more than the parts board?
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
Re: Porterbuilt older style hood hinge brackets?
I talked to dave at porterbuilt about the very same thing and he said they are gonna start making them again, but said something about the schematics being on a frozen hard drive that needs unlocked. I like those better also compared to the cowl hinge
Nate told me he spent enough time looking for the files and does not plan to offer them in the future. That's why I'm trying the forums now.
67-72 parts collector,…
![]() Join Date: Nov 2002
What's wrong with the cowl mount hinges?
Dont imagine that it would be that hard to recreate if you can find a set to remeasure. I was gonna attempt it myself. The cowl hinges are a poor design in my opinion. You gotta take a hood propwith you everywhere you go
Nothing if you want to cut up the cowl and weld to the hood, but I want to run tubular bracing from the front of these out and down to my front frame horns and then add a cross brace, all of which will bolt in and be removeable. I can make my own if I have to, but the Porterbuilt ones are nice and thought I may luck out and find a set.
Anybody got a pic of them mounted up???
I wanted a set of these too , they told me same thing about being lost
///Relaxed Atmosphere |
1961 crewcab
these might be a better option for someone that just wants a bolt on item.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
x2. Been hoping to come across some as well to duplicate.
Hopefully, someone that already has a set can supply/offer up dimensions (since the original mfr has no intention of offering these again because they're out-dated).
#13 |
They were on Dino's crew cab when it was still a single cab.
His panel may also have them. Seems like Dino swapped them to a set of cowl mounted PB hinges. You might pm Dino. Posted via Mobile Device
#14 |
I guess I don't see why these would be needed...
Why would you remove the original hood hinges? -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
#15 |
#16 |
No OE inner fenders = no OE hood hinges unless there's something to bolt them to @ the firewall (that's what these pieces are).
#17 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I could probably make some up as long as Nate was OK with it. Would need some basic measurements though.
#18 |
Ah. No inner fenders... Much clearer now.
Thanks. -Brad
#19 |
Did anything come of this? I would like to find myself a set as well.
#20 |
I ended up getting a new set from another member who didn't use them because he ordered the newer Porterbuilt hinges.
#21 |
I'd sure like to find a set
#22 |
#23 |
Hey durg, is there any way you could send me measurements?
Posted via Mobile Device |
#24 |
The only critical dimensions are for the hood mounting hole locations and the holes that they mount to on the firewall and how they relate to each other, which are all the same measurements as your stock inners so you should be able to get those from your stock ones. If there is something specific in addition to those measurements you need, let me know what dimensions you need.
#25 |
bump. any body have the older ones or ended up making some that i could purchase?
63 big window lwb bagged and shaved |
