Old 02-17-2013, 10:16 PM   #1
Flatpat
Flatpat's Avatar
Dangerous situation, need some help please
I have a 1978 K30 Crew Cab that I have been getting back on the road. I'm having an issue where if I take a fairly sharp turn at a little bit of speed (15-25mph), the truck will start a very violent wabble, like the tires are going to fall off. If I slow down to a crawl it stops and then I can continue on and it rides great. It doesn't do it on slower turns or the sweeping highway turns and so far it's only done it on right turns. I made sure all the wheels are on correct and the lugs are torqued down. The tires are radials and in pretty good shape. Figured it wasn't a tire since it straightens out. Best I can tell everything is connected throughout the suspension and nothing appears broken. Any ideas? It's pretty scary.
Thanks,
Patrick
Flatpat is offline   Reply With Quote
Old 02-17-2013, 11:01 PM   #2
Rusbuilt
Rusbuilt's Avatar
Re: Dangerous situation, need some help please
Is your suspension stock?
Rusbuilt is offline   Reply With Quote
Old 02-18-2013, 01:46 AM   #3
Flatpat
Flatpat's Avatar
Best I can tell it's stock.
Old 02-18-2013, 03:40 AM   #4
JTRACEY
I can tell you that I was driving a buddy of mines truck, and when I hit a bump, or took a rather fast turn the same thing would happen until i slowed down. When i got below 10 it would go away just like you said... It ended up being his wheel bearing... Not to mention the damn things were less than 6 months old...
JTRACEY is offline   Reply With Quote
Old 02-18-2013, 05:58 AM   #5
andrewmp6
Its known as death wobble the whole front axle will jump around.As how to fix it i don't know on a leaf spring truck but some on here will tho.
andrewmp6 is offline   Reply With Quote
Old 02-18-2013, 06:04 AM   #6
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
I had a bronco that did that. Turned out to be a wheel bearing. I found that out after the whole locking hub assembly blew out.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 02-18-2013, 10:09 AM   #7
Bret B
Something else after checking those ball joints/king pins, and wheel bearings, consider adding a steering stabilizer. The "Death Wobble" has been talked about a lot on solid axle trucks on other sites. It isn't just a GM, Ford, or Dodge issue, but happens with some solid axle trucks. After doing the Dana 60 solid axle swap from the Dana 50 TTB, I added the stabilizer and could really tell the difference. I don't know for sure what the wobble is from, but from what I understand it is caused by the steering parts wearing out quicker than other parts because of the stresses put on them.
1965 Chevy short-step side, work in progress....
............................____
..................______l/___\____
.................|_/(0)\_ll____/(0)_l.
Bret B is offline   Reply With Quote
Old 02-18-2013, 11:31 AM   #8
Flatpat
Flatpat's Avatar
Thank you for the input everyone. I'll go through and take a look at the bearings and a stabilizer.
Old 02-18-2013, 08:48 PM   #9
LONGHAIR
It's more of a Dana60 thing than just blaming it on "straight axle". It happens because of the difference in the ball-joints. The D60 doesn't have the traditional ball-joints like the D44 or GM 10 bolt does. It has a tapered (roller) bearing for the lower and a similarly shaped solid slug in the upper. The uppers are "spring loaded" under that 4 bolt cap. IIRC, someone makes a shim kit to eliminate the spring? But I haven't messed with a D60 for many years.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-19-2013, 01:01 AM   #10
Flatpat
Flatpat's Avatar
Thanks LONGHAIR, I ran across the springs online earlier. I'll have to see what "fixes" are out there.
