Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-17-2013, 10:19 PM   #1
65chevysub
65chevysub's Avatar
1 Piece driveshaft
Is anyone running a 1 piece driveshaft in their burb? I had one made back in the 90's, but it seemed to vibrate more than the 2 piece, even with new U-joints. I have some literature from GM on the '65 Chevy trucks, and it says that the 'burbs all had 2 piece shafts but the pickups only had a 1 piece. Is there a reason for this. I'm wondering if I should take my 1 piece to an actual driveline specialist and have it checked, as it has regular washers as weights on it, and it was done by a muffler/ driveline shop.
65chevysub is offline   Reply With Quote
Old 02-17-2013, 11:01 PM   #2
hd74
Re: 1 Piece driveshaft
i piece driveshaft on my 1963 gmc
hd74 is offline   Reply With Quote
Old 02-17-2013, 11:31 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
My '60 GMC suburban and my old '60 GMC truck both had factory one piece driveshafts. I think maybe the two piece shafts might have come out when they changed the frame in '63.
Old 02-18-2013, 02:38 AM   #4
Captainfab
60-66 Nut
My '66 Brub has a one piece driveshaft. I assumed all Burbs and shortbed trucks had one piece driveshafts, and all longbeds had the 2 piece. I've not seen a shortbed or Burb with a 2 piece driveshaft.
Old 02-18-2013, 04:57 AM   #5
RockTonka
RockTonka's Avatar
66 burb here with two piece drive shaft...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 02-18-2013, 05:45 AM   #6
padresag
perhaps it is the ones with the 4 speed that have the 2 piece and the 3 speed and a/t with the single d/shaft???
ron
padresag is offline   Reply With Quote
Old 02-18-2013, 08:22 AM   #7
tincan1966
tincan1966's Avatar
I learned from a previous project that driveline vibrations can be associated with the angle of the trans and pinion. Regardless of either 1 piece or 2 piece, the trans and pinion angle have to be the same.
I learned this after finding out the previous owner of my '69 C30 had shimmed up the trans mount about 1/4".
I found a good website that explained it all, I wil try to find it again and post the link
tincan1966 is offline   Reply With Quote
Old 02-18-2013, 10:48 AM   #8
VictoriaHardware
VictoriaHardware's Avatar
My '66 Sub is all original and has a one piece. It has a 292/Powerglide
VictoriaHardware is offline   Reply With Quote
Old 02-18-2013, 12:28 PM   #9
65chevysub
65chevysub's Avatar
Thanks everyone. Mine is the 2 piece, factory. It originally had the 292, with a P/G trans. The biggest problem I had was my carrier bearing kept breaking where the spot welds were on the threaded plate. I finally drilled them out and put 4 small bolts, lock washers and nuts on it to keep it together. So far so good, on the fix.
Old 02-18-2013, 01:45 PM   #10
hemifalcon
My '65 has a one-piece shaft.. It's a 4speed with 292... I prefer the heavy 1-piece unit rather than the multi-piece shaft with the center support bearing. Trucks that are 4x4 would obviously benefit from the extra articulation point.
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 02-18-2013, 02:47 PM   #11
padresag
that blows my question out of the water
it does not seem to be make specific either(chev or gmc with different rear suspensions). there must be an explanation for it some where
in a 4 x 4 the independent t/case acts as the centre supprt except for the frt shaft
ron
Old 02-18-2013, 04:50 PM   #12
Brad54
Brad54's Avatar
My '62 Suburban (I've cosmetically changed it over to '61) was factory V8, Granny 4spd, 1pc driveshaft, with the slip-yoke built in to the driveshaft.
I converted to a 4spd OD manual trans, and had a new 1pc driveshaft built by a driveshaft shop.
My vibrations have more to do with worn shocks, worn rear suspension bushings and worn front suspension. I also lowered the truck a bit, and never got around the resetting the rear pinion angle, though it's probably only out by a degree or so.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 02-18-2013, 04:55 PM   #13
64fleetside
One piece on mine, was ?/4 speed now 350/700r4.
64fleetside is offline   Reply With Quote
Old 02-18-2013, 04:57 PM   #14
MusicMan70
MusicMan70's Avatar
My 61 GMC 305 V-6 and SM420 , had the two peice driveshaft. Since the OD conversion, I have a one peice DS.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-18-2013, 06:59 PM   #15
RockTonka
RockTonka's Avatar
Mine from above was 283/PG with 2-piece...??? Anybody see a pattern??
My build thread
Old 02-19-2013, 01:15 AM   #16
rustyrodknocker
My burb was converted to one piece with th350 doin the same to my panel.
rustyrodknocker is offline   Reply With Quote
Old 02-19-2013, 02:07 AM   #17
Captainfab
60-66 Nut
My '66 Burb was originally a 283/PG with a one piece.
This is all interesting info., I just don't see a pattern to the one piece/two piece driveshaft situation. I wonder if it had to do with where the truck/burb was built? Mine was built in the Fremont plant.
Old 02-19-2013, 09:07 PM   #18
MikeS.
MikeS.'s Avatar
My 63 4x4 is one piece. My 66 LB truck was 2 piece.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 02-19-2013, 09:28 PM   #19
Keith Seymore
Keith Seymore's Avatar
Driveshaft critical speed is what determines the allowable shaft length.
Critical speed (the point at which the shaft bends and starts swinging like a jump rope) is a function of shaft length, diameter, material and rpm (which is a function of vehicle top speed and rear axle ratio). Plus - if there is some odd system resonance that the shaft is responding too that can cause problems.
This is why trucks that are somewhat similar might have a difference between one piece and two piece. Could be the same truck but with a different rear axle ratio, for example, that drives the different release.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-19-2013, 10:53 PM   #20
MusicMan70
MusicMan70's Avatar
Originally my 1961 GMC suburban (V-6) 2wd had a 3.92 rear ratio with Trac Loc and a two peice DS
MusicMan70
1961 GMC Suburban
Old 02-20-2013, 01:41 AM   #21
Captainfab
60-66 Nut
My Suburban originally had 3.73 gears.
Mr. Seymore, I would like to hear your input regarding the standard top mount carrier bearing (as seen in post #5 above) versus the heavier duty carrier bearing that mounts on the bottom of the trailing arm crossmember, as more commonly seen in C20 and up trucks.
I'm not a fan of using the light duty top mount carrier bearing with small diameter shafts in a higher horsepower/performance based truck. I have always used the HD carrier bearing and larger diameter shafts with virtually no issues. There is a thread in the 'Racing and High Performance' section, discussing the durability of the LD carrier bearing and shafts in a racing application.
Old 02-20-2013, 08:22 AM   #22
Keith Seymore
To be honest, I don't have a lot of experience with 2 pc shafts in race/hi performance applications.
I have always converted to a one piece (when I could get away with it) for simplicity's sake.
Intuitively, though - bigger is going to be better when talking about center bearings and shafts, in this case....
K
1979-1986
1986 - 2019
Old 02-22-2013, 12:35 AM   #23
Captainfab
60-66 Nut
Thank you for your reply
Regarding the carrier bearings. For me it is a no brainer which one to use, when you compare the two.
K
