Old 02-18-2013, 05:38 PM   #1
Dova
Dova's Avatar
What is this part?
This is connected to red wires as you can see in the pics. one of the red wires went all the way to the rear bumper but then a PO cut it just leaving it open ended. Any help would be greatly appreciated. This started out as my brake lights didn't work. Come to find out that all the wires are spliced into from the cab and reran to the rear end but then the wires are cut back there. so rewiring today.
Dova is offline   Reply With Quote
Old 02-18-2013, 05:53 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: What is this part?
top pic is a ford style starter solenoid
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 02-18-2013, 06:04 PM   #3
Dova
Dova's Avatar
The other pics are what it's connected to. Why would someone put one on a Chevy?
Old 02-18-2013, 06:18 PM   #4
hayhauler71
hayhauler71's Avatar
My have been used as a relay to run power to a camper or topper. Is there a switch in the cab that controls the relay?
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 02-18-2013, 06:50 PM   #5
68Gold/white
or to charge an extra battery in camper. or such
68Gold/white is offline   Reply With Quote
Old 02-18-2013, 07:45 PM   #6
SS Tim
SS Tim's Avatar
That is probably a continuous duty solenoid but from the looks of the wiring it may very well be a starter relay being improperly used. Charging or powering a camper or trailer would be my guess as well. No matter what clean up is needed. Might be best to start with a factory wiring diagram from the service manual for your model year and work through it one circuit at a time.
SS Tim is offline   Reply With Quote
Old 02-18-2013, 10:49 PM   #7
Dova
Dova's Avatar
That's the intention. Thanks and I think that's what it was probably used for. I'm cleaning it up as I can.
Old 02-19-2013, 06:54 AM   #8
luvbowties
luvbowties's Avatar
Thumbs up Re: What is this part?
I've seen just that used to power a small winch mounted on a trailer.
Sam
luvbowties is offline   Reply With Quote
