Old 02-18-2013, 07:14 PM   #1
jerry73
front brake adjustment?
This morning I got in my truck and drove down the street and the truck is pulling hard to the RIGHT...it wasn't doing it yesterday but since I got the truck it pulled hard to the LEFT every time you hit the brakes..... Any suggestions? I've already checked all the the tire pressure and its all good. Thanks in advance
jerry73 is offline   Reply With Quote
Old 02-18-2013, 07:56 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: front brake adjustment?
Collapsed brake hose or stuck caliper.
Keith
Convert to disc brakes.
Old 02-18-2013, 08:52 PM   #3
jerry73
What can I do about the stuck caliper? That sounds like what it is
Old 02-18-2013, 09:07 PM   #4
LONGHAIR
Replace them both and start from square one....it's probably best to replace the hoses too. They collapse internally over time and you can't tell it from the outside.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-18-2013, 09:27 PM   #5
rwhit57
rwhit57's Avatar
I don't disagree with this plan, but if you don't have the funds or the calipers look good do the hoses first. Most of the time that will cure it.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 02-18-2013, 11:18 PM   #6
rs74
rs74's Avatar
I have made it a practice to always replace the hoses when replacing calipers.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-19-2013, 01:25 AM   #7
jerry73
Do you guys have any preferences for websites I can buy parts for this truck from.....I want to get some braded stainless steal hoses so LMC wouldn't be a resource I'd want to use....sites with after market stuff
Old 02-19-2013, 01:57 AM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
Summit.
If you get brake lines spend $75 and get stainless braided lines from russel
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-19-2013, 10:14 AM   #9
rs74
rs74's Avatar
Originally Posted by INSIDIOUS '86 View Post
Summit.
I would second on the Summit. Although I only bought the rear brake line kits. They were stainless. The axle lines were $31.50 and from the rear end up to the front was $45. Then there was the front hard line kit which I didn't order. I think it was something like $91. The brand was "Right Stuff Detailing". In case anyone wanted to know.
Roy
1987 R10 shortie
Old 02-19-2013, 10:33 AM   #10
krazy_texan
krazy_texan's Avatar
Honestly as cheap as calipers are at your local parts store might as well replace them while your in there. I think for both mine I paid $24 I got a good deal on rotors and hoses from Rockauto.com I think I had less than $60 total in all that
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-19-2013, 11:35 AM   #11
jerry73
Well I'll have to check around at stores around here Napa tends to be pricey even for there own brand of things...m definitely going with summit for a few things already because how much cheaper they are
Old 02-19-2013, 12:09 PM   #12
rs74
rs74's Avatar
I used to be a diehard Napa parts user. Here in the last few years it seems like there brakes have really suffered though. I like to shop local but the prices are a bit more. Here lately I have been buying online for the price. Some of the stores say they will beat anybodies prices but when you mention Summit or somebody like that then it is a different story.
I saved over $100 on my front suspension parts through Summit and they were the same brand parts. Let alone I added on a drop kit and all new steering components. Probably saved $3-400 by going through Summit. I called RockAuto and they didn't have what I needed. I don't have any other experience with them. I am sure they are great to work with. I hear alot of good things about them here on the boards.
Sorry for the rant. Just my expereince.
Roy
1987 R10 shortie
Old 02-19-2013, 10:33 PM   #13
jerry73
Yea I agree I usually like to search around real hard for low prices before I buy...online has been my best experience so far
Old 02-19-2013, 10:40 PM   #14
rs74
rs74's Avatar
Just watch what you get. Sometimes you get what you pay for buying cheap.
Roy
1987 R10 shortie
Old 02-19-2013, 11:40 PM   #15
big10ratrod77
big10ratrod77's Avatar
you can always break loose the bleeder screw and try to push the piston back into the caliper, if is pushes back with the bleed screw open than the line is bad, but if you cant push it back than the caliper is stuck, BUT like thes guys said always replace the hoses with the caliper if you do replace it its what you call CYA if ya know what a mean, ive had some jobs at work come back and bite me in the butt becouse of a collasped hose, also if the hoses are realy old and dryrotting they need to be replaced anyways. good luck bud
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 02-20-2013, 03:57 AM   #16
jerry73
Well I didn't do much today because the weather is horrible but just for a small update I jacked both front tires up of the ground and they both drag alittle...is this normal? It seems to be a consistent equal drag on both sides. By drag I mean when I spin the wheel when its in the air
Old 02-20-2013, 04:04 AM   #17
piecesparts
Parts and more parts
piecesparts's Avatar
There will be a small amount of drag on a disc if the pads are touching. I agree that your problem may just be the front hoses to the discs. If the truck is pulling to the left, then it is probably the right hose is failing and restricting fluid to the disc. Replace both and do a purge of air from the brakes on the front. Your problems may be cured that easily.
Frank
piecesparts is offline   Reply With Quote
