![]() Join Date: Jul 2001
Wanted correct 72 valve covers,air cleaner
I would like to find a set of original 72 valve covers. They should have 2 openings on each cover, one small,one larger opening
Also want an original air cleaner For a 350. Would like to fine nice non rusty,dented items Thanks Ray Posted via Mobile Device Posted via Mobile Device
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
![]() Join Date: Oct 2012
Re: Wanted correct 72 valve covers,air cleaner
I have both, in original condition, would sell as is or I also have access to sandblasting and powder coating if you wanted that also, pm me for info.
Posted via Mobile Device |
I have both also and pictures if your interested?
Is this what you're looking for?
Mine is similar but the oil fill on mine is the long neck filler
Casey, yes I think so. Funny you posted these, I was going to ask you, but I figured you would of posted them in your adds.
The valve cover with the oil fill tube, is the flange bent? Right front mounting hole
thanks, Ray
No I just removed, it bolts to intake right under the carb linkage
Oh I see what you're talking about, no it must be an optical illusion...
![]() Here is the one you inquired about on another post,zero pitting or dents.Freshly blasted and powder coated,with a 4 barrel spacer and new Napa Gold element. |
