02-18-2013, 08:46 PM | #1 |
clutch related parts
Was gonna swap my blazer from a auto to a 4 speed but sold the blazer and parts need to go, most all the parts are new in there packages, Hays super truck clutch kit 90-102 $309.99 on jegs, sachs flywheel nfw1007new clutch and flywheel bolts, trans transfer case boots with alum trim rings, 2 new shift knobs no lettering on them 1 old shift knob with patteren on it, greasable transfer case shifter bolt gm, upper clutch linkage, z bar frame mount, transfer case support bracket, clutch fork,1 straight shifter from a 72 k5, 1 shifter with bend at top, 1 np205 shifter from 72 k5,clutch/brake pedal pads, new z bar with all new felts,clips studs,nuts,washers ,clutch pedal bumpers,clutch fok boot,clutch rod boot, etc Im probably forgetting something but its all in the pics everthing is there to do a 4 speed swap of replace your old wore stuff only thing not in pics is the 4 speed pedal assembly, I got a good sm465 and np205 from a 72 k5, I got over $800 in the parts in the picures alone ill take $800 for everything in the pics and the sm465/np205. Ill sell without the trans and transcase if it helps someone, Would rather stuff be picked up in person the clutch and fly wheel are heavy so im sure that would make shipping high, Thanks Josh |
02-18-2013, 10:12 PM | #2 |
Re: clutch related parts
if you decide too split this up
I would be intrested in pedal pads bell houseing boot firewall boot both springs adjustment rod
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
02-19-2013, 10:28 PM | #3 |
like to keep it all together right now . Thanks
02-23-2013, 01:33 PM | #4 |
Sold !
02-24-2013, 07:51 PM | #5 | |
I may have the boots and the adjustment rod if V8 is the same as inline 6. I don't know if they are the same. If you know they are and you are interested, let me know. These would be used parts. Thanks, Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-25-2013, 08:04 AM | #6 |
thanks I'm not sure if they are differnt either I already have most of the parts but i seem too be missing a felt washer and my boot crumbled too bits so I was just hopeing too pick up some fresh peices I can get some of those at the jy probally freebies but thanks for looking out
02-25-2013, 01:59 PM | #7 |
No problem, let me know if you can't find em at the 'yard.
02-25-2013, 06:08 PM | #8 |
cool thanks
