Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 02-18-2013, 09:08 PM   #1
1972k5blazer
ord lift parts with springs
Size:  76.2 KB Was gonna do a 4 in rear shackle flip lift but sold my blazer,Triangle spring company stock springs for rear new , tuff country 4in hd front springs new , greasable hd front shackles,greasable main eye kit for aftermaket front springs, 4.5 in rear super shackle with greasable rear upper shackle and spring eye kit all bushings are 1.5 in, 1in zero rate add a leafs 2 1/2 in wide not in the pics is a dana 60 u bolt kit and rear u bolt kit 3/4 ton 73/87 spring lift, only thing i didnt get arount to getting is the rear 4 in shackle flip that you bolt to the frame they are $167 on ord you can use other companys also , I got the recipt thats $467 for the odr parts alone not counting the 4 springs ill take $500 picked up for everything shipping would probably be crazy high since everything is heavy. Thanks Josh
1972k5blazer is offline   Reply With Quote
Old 02-20-2013, 09:33 PM   #2
highrpm
Re: ord lift parts with springs
Would you sell just the front bushings and shackles?
highrpm is offline   Reply With Quote
Old 02-21-2013, 02:47 AM   #3
Jdubs71
Jdubs71's Avatar
Also interested in just the front shackles if your going to part it out and highrpm passes
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 02-21-2013, 06:19 PM   #4
1972k5blazer
Like to keep it all together I tried to price it cheap enough where I hoped it would sell fast
Old 02-21-2013, 09:17 PM   #5
Jdubs71
Jdubs71's Avatar
I would definitely take it all if you were local. Shipping would be a couple hundred.
My build thread
Old 02-23-2013, 01:36 PM   #6
1972k5blazer
Okay i sold some clutch parts i had on the truck side of the site so ill come down a little to get rid of this stuff i hate to see it sitting around and im not gonna use it ill take 400 bucks picked up !
Old 03-23-2013, 02:01 AM   #7
Motero101
Where in Az are you located im in NM.
Thanks,
Mike
Motero101 is offline   Reply With Quote
Old 03-23-2013, 02:42 AM   #8
Motero101
NVM your in AR not AZ sorry.
Old 06-16-2013, 03:08 PM   #9
yellow70
yellow70's Avatar
Hi, would this setup fit a 70 or 71 blazer ?
yellow70 is offline   Reply With Quote
Old 06-19-2013, 08:58 PM   #10
yellow70
yellow70's Avatar
Does anyone know how to contact this member other than this site, I could use these springs if they fit a 70-71 blazer, I have got the rear end out of my blazer waiting on word from him ! Thanks
Old 06-19-2013, 10:16 PM   #11
briank
Your only hope is somebody on here knows him and contacts him for you. He hasnt had any activity on here since 4/27
briank is offline   Reply With Quote
Old 06-20-2013, 09:42 PM   #12
yellow70
yellow70's Avatar
ttt
Old 07-08-2013, 06:23 PM   #13
davischevy
davischevy's Avatar
I sent an email to friend over there. Maybe he can find the OP.
davischevy is offline   Reply With Quote
Old 07-08-2013, 08:34 PM   #14
yellow70
yellow70's Avatar
Thanks davischevy, I already have them under my blazer !
