Old 02-18-2013, 09:23 PM   #1
restorationboy14
How to take out bell housing?
I'm replacing my Saginaw 3 speed tranny. The input shaft is stuck to the clutch plate so I have to take the bellhousing off. I was planning to do this anyway but I want to knowbwhat I'm doing before I start unscrewing bolts. I also have another question. I was taking out my water pump and the lower drivers side bolt head busted off. I've already somewhat drilled it out. How do I re tap it? Thanks for the help!
restorationboy14 is offline   Reply With Quote
Old 02-18-2013, 09:28 PM   #2
Gumby
Gumby's Avatar
Re: How to take out bell housing?
have someone push in the clutch as you wiggle it out/lose....
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 02-22-2013, 11:49 AM   #3
restorationboy14
I already tried that and it didn't work. I'm going to have to take out the bell housing anyway so I just wanna know how to take it out. Thanks!
Old 02-22-2013, 02:15 PM   #4
Racer2172
Unbolt the 6 or so bolts from the motor that attach the bell housing to the motor. Also make sure you disconnect the clutch arm from the linkage. If the clutch plate is stuck to the input shaft you will have to unbolt the clutch from the flywheel as well. Depending on space tools and how soon you have to put the truck back together. It might be easier to pull the motor and transmission to get it out where you can work on everything with more room.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 02-22-2013, 02:41 PM   #5
Gumby
Gumby's Avatar
If your that unsure about taking it apart, get some help that has done it before, a clutch is easy to do, but can be screwed up just as easy.
