5 on 5 to 5 on 4 3/4 ???
i have a 61 short wide, changed the old rearend and the front cross member to 1980 running gear. can it be converted from the 5on5 bolt patern the more popular 5on4 3/4?
..."what is everybody using to post pics"...
Our home uses a free photo-ed ap called PICASO; downloaded from the 'net. Lucked up on it several years back and really enjoy it--easily intuitive and does ALL we non-shutterbugs ![]() HTH, Sam |
Re: 5 on 5 to 5 on 4 3/4 ???
Photobucket!
People who make excuses didn't want to do it in the first place! ![]() http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
#4 | |
![]() Quote:
![]() Maybe someone will chime in with info on rotors that will work on the front. Else, if adapters are available with 1-inch width, they would make your front wheels/tires track more nearly with the rears: you're already 3/4-inch wider, per side, on rears just from the diff'l change. Such adapters would cut the difference to just 1/4-inch, now wider on the front, which your ride should be able to handle. sam |
thanks for the help. tried photobucket but the photos never show up gonna try something else.
SIR
..what's wrong with what you have....there's lot's of choices in that pattern range...and there stronger!!
66long low fleet http://community.webshots.com/user/LVNR66 |
![]() ![]() It ain't yours, if you didn't build it! |
Senior Enthusiast
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#9 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
That is for converting to front discs using the original '63-'70 spindles. The OP has already upgraded the front of his '61 with a '80 crossmember and complete suspension.
I agree with Kieth. Why not stay with the 5 x 5" wheel stud pattern?
You're right Capn'! I didn't notice that in his thread. I agree the Capn', just stay with 5 on 5, the hard work has been done.
I just drilled the 5 x 4-3/4" pattern into new 91 burb rotors (cost 17.00 each) installed new studs and away she went. cost $50.00 ...
#13 |
ok ok. i will leave them 5 on 5. the only reason i was looking to change was i found a set of torque thrust rims 18 x7 for dirt cheep and that was the rim i wanted. on the other question, i have tried to post pics from photobucket, picasa and imageshack, and it still wont post to the site. am i doing something wrong. ive tried single pics and from a url.
#14 | |
![]() Quote:
HTH, Sam |
#15 |
Maybe you can buy them, and trade them later for another set that's 5 on 5 or sell for a higher price to fund what you want.
jmo
#16 |
60-66 Nut
Did your rotors have the ribs in between the original studs on the back side. All the C10 5s5 rotors I have seen have those ribs on the back side. It seems like those ribs would pose a problem with drilling a second bolt pattern in between the original.
#17 |
thanks LUVBOWTIE it worked.
#18 |
and some more.
