Old 02-19-2013, 02:04 PM   #1
restorationboy14
How to take out bellhousing?
I'm replacing my tranny and clutch. How do I take it out?
restorationboy14 is offline   Reply With Quote
Old 02-19-2013, 02:07 PM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: How to take out bellhousing?
What year is your truck? If you have the trans out already, there is between 4 and 6 bolts that hold the bellhousing on. The bolts at the top of the block can be a pain to get to. A nice ratchet type box end wrench is handy to get them out.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 02-19-2013, 03:21 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
If it is a Chevy, anything from 1955 to 1998 V-8's will have six bolts. I have had good luck on pick-ups getting the top two bolts from under the hood. You will have to sit under the hood and but if you have limited tools, then you can do it that way with a normal 9/16 wrench.
There also may be a spring connected to the throw out bearing fork you will have to disconnect.
If the starter is bolted to the bellhousing, remove it from the bell housing before unbolting the bell housing from the engine. Make sure you disconnect the battery first.
TBONE1964 is offline   Reply With Quote
Old 02-19-2013, 07:16 PM   #4
restorationboy14
Sorry for the lack of info. Its a 1969 GMC pickup 292 inline 6 3 speed on the floor. Its all original. Thank you very much for the help. Sorry I was in a rush to post this haha. Thanks!
Old 02-19-2013, 07:40 PM   #5
Bishops Trucks
KEEP ON TRUCKIN'
Glad to help. Hope the info was helpful for ya.
JIM
Old 02-19-2013, 07:49 PM   #6
Gumby
Gumby's Avatar
jack up on the front engine balancer, not allot or go crazy, just enough to tilt it back so you can get them from below, if up top is to hard.
[v8 guys, remove dizzy first]]
If the tranny was still on, it would do this for you, with its weight.
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 02-19-2013, 08:53 PM   #7
Daner
Daner's Avatar
When I took out my 250 with a 4 speed I only remember 4 bolts. 2 on the "inside" and 2 on the upper backside. Yeah the ratcheting wrenches work real good. I accessed them from underneath.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
