![]() Join Date: Feb 2005
Big Block Parts for Sale
All prices are plus shipping. Please reply in thread,first Ill take it gets the part.
3 groove water pump pulley off of a 72 GMC 402 short pump good condition $20.00
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
Re: Big Block Parts for Sale
2 groove water pump pulley for short pump,great condition. $30.00
68-71 Big block frame brackets,excellent condition. $60.00
I will take it all pending shipping to 58265
Posted via Mobile Device |
Big Block valve covers off of a 72 GMC 402 good condition. $40.00
Set of Big Block pulleys,3 groove short water pump pulley,2 groove crank pulley and crank pulley for power steering. All in good shape. $75.00
I will also take the valve covers and 3 pulley set pending shipping to 58265
Big Block exhaust manifolds off of a 72 GMC 402. No cracks or broken studs. Have holes for AIR injection. Injection tubes have been folded over to close. No leaks when last used. $80.00
Roadtrip!
![]() Join Date: Feb 2003
When the smoke clears, let me know what is left for pullies or any BB brackets.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Jun 2005
Those frame brackets look line inline style. If they really are big block, I will take them if Brett passes.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Sorry folks,put wrong pic on big block frame mounts. This is the correct pic. By the way the 6 cylinder mounts are available for $25.00 plus shipping. Sorry for the confusion.[/B]
MadnessBigBlock, do you mean all of it or all of it up to where you replied? That would exclude manifolds. Will get to everyone else once I get a reply. Thanks.
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 Last edited by zeusflash; 02-19-2013 at 06:34 PM. Reason: Misspelled name |
#13 |
I would like the:
3 groove water pump pulley 2 groove water pump pulley The set of three pulleys And the big block mounts ( by the picture it looks like soneone has trimed the corner off. Is it just me or is that true) Posted via Mobile Device |
#14 |
I could use just one set of pulleys, if the other guy decides not to be greedy. I need the water pump pulley and the crankshaft pulley's. If he does take all of them could you do me favor and post the part numbers off them. I may already have the right ones but I do not know the part numbers to check. Thanks.
#15 |
Will check on that MadnessBigBlock. Will check those numbers too.
#16 |
MadnessBigBlock,PM sent
#17 |
Looks like 3 groove water pump pulley,valve covers,exhaust manifolds and frame brackets are still available. Price on brackets reduced to $50.00 due to cut on right side bracket. Does not affect function or strength and cannot be seen with motor installed.
#18 |
I will take the BB engine stands pending shipping cost to 46562. Should fit into a medium flat rate box for around $12. If so, I will take them.
Thanks, Mark
#19 |
Roadtrip!
How much to ship the 3 groove pulley to 55744? Any other BB brackets?
Eric
#20 |
PM sent to 70stovebolt and Too much stuff
#21 |
I will take the 3 groove water pump pulley as long as it is for a short water pump (I think that is what you said it was for) if stovebolt does not . Price to 46373, will pay with postal money order. Also could you post those part number's off the pulleys if you can find them. Thanks.
#22 |
I was not in for a pulley, I want the BB frame stands. Money order in the mail for $62.35
I think Eric (toomuchstuff) needs the pulley. Thanks, Mark
#23 |
70stovebolt got the brackets
Too much stuff got the pulley
#24 |
Valve covers and exhaust manifolds still available. Make offer.
#25 |
![]() Join Date: Sep 2007
How about $30 for the valve covers? Shipped to 97050
