![]() Join Date: Feb 2005
Original Small Block Q-jet Intake Manifold
This is a 68 only small block intake manifold for a Q-jet carb with the front oil fill for use with early style valve covers with no holes. It includes the oil fill cap and the thermostat cover. The manifold is in excellent condition. Clean and paint and it will look new. The heat riser ports at the carb flange have been plugged an easy fix if you would like them to work $65.00 plus shipping
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
Re: Original Small Block Q-jet Intake Manifold
Offers?
Ttt
![]() Join Date: Mar 2011
Can you post thecasting #s of it
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
![]() Join Date: May 2007
could you see what shipping would be to 20751
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Casting number-3919803. Gotta box up and get dimensions and weight for shipping estimate. Weighs about 40lbs. Please be payient with me as I am working with a broken thumb.
Duallyjams,PM sent
