Old 02-19-2013, 05:34 PM   #1
yellow400ex05
Question What is the button in the middle of wiper switch for? 66 c10
Might be a dumb question but is the button on the knob of my wiper switch for setting the wiper speed? I'm having trouble keeping my wipers on when I turn the knob on. And if I press it it stays in and keeps the wipers on.
yellow400ex05 is offline   Reply With Quote
Old 02-19-2013, 05:39 PM   #2
Idaho64GMC
Re: What is the button in the middle of wiper switch for? 66 c10
any chance you have a picture?
Idaho64GMC is offline   Reply With Quote
Old 02-19-2013, 05:40 PM   #3
TopFuel1966
TopFuel1966's Avatar
It runs the washer pump if you have one.
TopFuel1966 is offline   Reply With Quote
Old 02-19-2013, 05:42 PM   #4
austin60c10
austin60c10's Avatar
Yeah, washer pump mine has that switch too, anyone know where to get a replacement mine is on its last legs and I haven't been able to find any aftermarket ones that are anything like it. Mine is 2 speed with the pump switch.
austin60c10 is offline   Reply With Quote
Old 02-19-2013, 06:04 PM   #5
yellow400ex05
So these trucks only have 2 speed wipers?
How do I keep my wipers set to stay on?
Old 02-19-2013, 07:20 PM   #6
Hx16457
Hx16457's Avatar
By turning the knob once to the right (one click) you get slowest function out of your wipers, turn it to the second click you get a faster slow function out of your wipers! Ha
Both slowest and faster slow are continuos functions!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 02-20-2013, 08:29 AM   #7
ol_skool_chevy
ol_skool_chevy's Avatar
nitrous oxide............dont touch that button
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 02-20-2013, 01:18 PM   #8
PoDuck
These guys just all think it would be funny if you pressed that button while going down the road.
It's really the ejector seat button.
PoDuck is offline   Reply With Quote
Old 02-20-2013, 02:56 PM   #9
awbrown
Not all trucks had 2 speed wipers and not all trucks had a washer either,, Those were expensive luxury items back then...
awbrown is offline   Reply With Quote
Old 02-20-2013, 03:08 PM   #10
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 02-20-2013, 04:26 PM   #11
ACK
ACK's Avatar
For us with the single speed wipers, can any of you with the fancy highfaluting 2 speed ones tell us which is the equivalent to our single speed ... the slow or the faster slow. I just gotta know.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 02-20-2013, 04:59 PM   #12
64fleetside
the two speed just gives you too slow or too fast, lol.
64fleetside is offline   Reply With Quote
Old 02-20-2013, 05:13 PM   #13
Billett
Billett's Avatar
same in my 68. Anyone do a conversion so we can have more than two speeds? Wasn't sure if there was a later model motor we could use, and I'm sure there's someone here clever enough to design a stock looking switch to go with it...
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-20-2013, 05:21 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Thats what I was thinking.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-20-2013, 05:27 PM   #15
64fleetside
Newport engineering lists a wiper motor wih a different design, has two speeds + intermittant-costs two bills though. Somehow for me it's hard to justify the cost on an unknown, I'm feeding two kids. Someone rich and single should guinea pig one....some folks have used the Cole-Hersee switch to get intermittant wipes.
Old 02-20-2013, 06:03 PM   #16
Billett
Billett's Avatar
don't think it's worth quite that much to me. It's just frustrating having to turn them on and off all the time or listen to the blade scrape against mostly dry glass...
Will
2024 Toyota Sienna
Old 02-20-2013, 07:47 PM   #17
markeb01
Senior Enthusiast
markeb01's Avatar
If the wipers are turning on and off at random, the most likely culprit is a defective dash switch or poor electrical connections between it and the motor.
If you don’t want to deal with the complexity of the factory washer setup, a simple option for is to install an inexpensive universal electric washer pump connected to a momentary push button or toggle switch. It might even be possible to wire in to the original knob/button switch. With this arrangement you can run the squirters independent of the wiper motor for as long or as short a time as you want. This avoids ever sweeping the wipers across dry glass.
I’ve added this setup to every vintage car I’ve owned since the 1970’s. This is typical of the type pump I’ve used, although they are changed so often I’ve never purchased two that looked the same.
With this type motor you’ll need a separate reservoir for the washer fluid. I normally use the factory 1980’s style plastic bottle. It mounts using bolts through two brass rivets so there isn’t any clumsy looking wire rack to get rusty. Or there are assemblies available including both the pump and reservoir for very little investment:
On our truck I was lucky enough to find a pair of factory squirt nozzles at a wrecking yard years ago. If original style nozzles aren’t available, there are numerous designs available at Amazon and Ebay by searching for “Windshield Washer Nozzles”. Also a lot of vintage small/foreign cars have many excellent nozzle designs to pick from.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
