Old 02-19-2013, 06:20 PM   #1
stock75
EGE valve making noise
hello all, hearing a slight " kuh-schinc" sound that i hear intermittently. Asked a buddy at an exhaust shop and he said its coming from the EGE valve assembly. Looked at my hayes manual and got an idea of what im hearing, thinking the valve flap is getting stuck either open or closed, any one here confirm that or have a similar problem? Not sure if its effecting performance, doesnt even sound too serious just bugs the heck out of me. was told i could wire the valve open, what do you guys think?
stock75 is offline   Reply With Quote
Old 02-20-2013, 03:45 PM   #2
stock75
Re: EGE valve making noise
bump for info*** is it maybe possible to delete the ege valve completely?? any drawbacks to doing this??
Old 02-20-2013, 08:17 PM   #3
Organism_ike
I think you mean the efe valve? Exhaust fume efficiency or something like that. Is the vacuum line still run to it and does it open and close freely? You can try moving the arm back and forth with your hands.
1983 Chevy C10 LWB
305 SBC bored .030 with cast dished pistons
Summit RV Camshaft 204/214 .424/.444
416 Iron Heads
Performer Intake, Quadrajet, and Flowtech Long Tubes
TH350 2.73 10 Bolt
Organism_ike is offline   Reply With Quote
Old 02-21-2013, 01:58 AM   #4
Duster
Duster's Avatar
Early Fuel Evaporation
Duster is offline   Reply With Quote
Old 02-21-2013, 11:06 AM   #5
stock75
like vapor locking?
Old 02-21-2013, 11:33 AM   #6
rfmaster
rfmaster's Avatar
Originally Posted by stock75 View Post
like vapor locking?
Nope - early fuel evaporation valve (EFE) was used during 70's into early 80's to restrict exhaust flow from a passenger side head when engine coolant was below a set temperature (TVS valve). The restriction forced exhaust gases to flow through intake crossover passage to the driver side and in the process warming up intake manifold quickly. I have nothing but four letter expletives for who ever came up with this system, but this is what GM had to do meet EPA mandates!
It is common for a flapper to get loose on the shaft - it was press fit, spot welded. Very common for it make rattling noises as gets old and rusty.
Check actuating vacuum canister - it should maintain vacuum while pulling rod in.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-21-2013, 11:48 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
my 79 removed it,have seen them cause different probs rusted/seized up here
if yours are are coming off i'd grind those bumps off inside too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-21-2013, 11:50 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
they do sell a piece to replace it
this may help show open or closed
John
Old 02-22-2013, 07:04 PM   #9
stock75
perfect!! thanks for the info guys, so from what i gather it basically helps with cold starts and warming up the truck faster?? anyways I think I am going to go ahead and remove it, dont like the look of the actuator assembly anyways, will removing it be pretty straight forward? just remove the actuating assembly and the flapper then plug the vacuum line that goes to the actuator right?? Thanks!
Old 02-23-2013, 06:45 PM   #10
stock75
bumppp for last question. i feel like these have been removed more than once, seeing as headers do not utilize this system, any advice on getting rid of it??
Old 02-23-2013, 09:52 PM   #11
donut
donut's Avatar
Exhaust studs "may" be too long if you remove it, If I ever dug that deep headers were going on. Over the years, many have been wired opened and left.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 03-12-2013, 02:22 PM   #12
stock75
Finally found some time to remove the efe today, when removing the power actuator will I need to plug the line that goes into it or throw a breather on it?? thanks! Plan on removing the power actuator and actuating rod then wiring the valve assembly open, anything im missing?
Old 03-12-2013, 07:46 PM   #13
donut
donut's Avatar
I don't remember where the vacuum line comes from, but it may have to be capped on the carb or switch side. Shouldn't need anything down on the exhaust manifold.
Old 03-14-2013, 10:09 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
yes cap it off at the carb
i'd check/feel/squeeze the other large hoses going to the base of the carb,i found mine dried/cracked split open,causing vac leaks
i used shorter studs
John
Old 03-15-2013, 12:28 AM   #15
stock75
Thanks for the great info guys!
Old 05-06-2013, 09:43 PM   #16
JCampbell
RF - You don't happen to have a part number for the TVS do you? It's hit and miss @ Napa...they have a half dozen to choose from and my old one is too thrashed to take in to compare.
JCampbell is offline   Reply With Quote
Old 05-07-2013, 11:34 AM   #17
rfmaster
rfmaster's Avatar
JC
Good question on TVS!! I hated EFE system 30 years ago and I still hated today. On the TVS - that part (for '84 305 with CA emissions) was long discontinued by GM, OE# 3053249.
http://www.gmpartswiki.com/getpage?pageid=59362
The main difference between most of these valves is actuation temperature - i.e when EFE valve is allowed to be fully open. Since the smog check is conducted on a fully warmed up engine - the temperature delta's between various part numbers are moot.
There are couple close functional equivalent made by SMP, part number: PVS48 which crosses to OE #14007803, 21272, 3043015 for use in C10 (1979 - 1984)
Thread Size - NPT: 1/2" - 14
Number of Ports: 2;
Number of Hose Connectors: 2;
Hose Size - Inches: 3/16" x 3/16"
Ported Vacuum Switch
Also SMP PVS116 is a better match for use in C10 (1983 - 1986) which crosses to OE #212106, 3053249
Number of Ports: 2
//RF
"The Beast"
Old 05-07-2013, 11:44 AM   #18
mgchevyparts
mgchevyparts's Avatar
error
mgchevyparts is offline   Reply With Quote
Old 05-07-2013, 01:36 PM   #19
JCampbell
Thanks, RF. I was gonna pop you an email, but I thought maybe someone else could use the info one day.
