Old 02-19-2013, 09:23 PM   #1
DRD57
Big Block / Small Block mounts
I'm working on a 68 Chevy pickup that has a small block in it. However, it's mounted in the forward holes of the cross member leaving several inches between the engine and the firewall. I believe this is the big block mounting location.
I plan to move it back to the proper location but, I'm not sure if the steel brackets between the rubber motor mounts and the cross member are the same for both locations.
Are there different brackets for small blocks and big blocks or do the same brackets work in different holes in the cross member?
Thanks,
Don
DRD57 is offline   Reply With Quote
Old 02-19-2013, 09:27 PM   #2
71Sixer
71Sixer's Avatar
Re: Big Block / Small Block mounts
They are different brackets.
71Sixer is offline   Reply With Quote
Old 02-19-2013, 10:08 PM   #3
sanford&daughter
sanford&daughter's Avatar
Welcome to the forums all v8 used the front hole the rear hole were for the 6. The front holes should be correct for your small block. Big block, small block and the 6 all used different frame stands
sanford&daughter is offline   Reply With Quote
Old 02-20-2013, 03:20 PM   #4
DRD57
Thanks for the info.
So, I guess the location is correct for a small block after all. The local "experts" told me it was wrong.
Does this look right to you?
Old 02-20-2013, 07:39 PM   #5
kaycee
kaycee's Avatar
Yeah u got it right the back hole is for 6cyl.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
