![]() Join Date: Oct 2012
Inner fender replacement
Is this supposed to be possible without removing the rad support? I fought mine for 2 hours last night and finally got the old one out by disconnecting the shifter linkage and twisting the bottom tab around enough to wrestle it out. But the replacement (used, not repro) does not want to go back in there. I've removed the everything from the rad support (washer tank, horn, voltage reg, etc..) but just cant seem to get it in there. If I get the firewall side in the front wont go down, and vice versa. I even tried unbolting the rad support on that side from the frame to see if it would move forward a bit and it's froze solid. Put a jack under the bolt and lifted the whole truck. As usual a "30 minute job" is going on 3 days....
1 thing at a time is progress.
Re: Inner fender replacement
Is the radiator support unbolted from the fender?
Alan
Philippians 2:14-16 |
Remove the outer fender... I've removed plenty of inner fenders in junkyards without removing the core support.
The battery tray is usually a *****, because acid fumes have not only rusted the bolts that hold the tray to the core support and the inner fender, but there's one bolt that is in a low spot, and the bolt head is often "chemically milled" down several sizes smaller than what it originally was. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Yes. I got the old inner out with a lot of twisting and contorting. Just doesn't seem to be enough room to get the new one in.
#5 | |
