Old 02-19-2013, 10:14 PM   #1
Franks69
Windshield Install ?
OK, here is the story. I called Advanced Auto Glass to put a windshield in my 1969 c10.They tell me for $205.00 they would install the front windshield. I tell them I need the front windshield and back glass put in with the gasket and trim. They said for $423.00 they would do both and they had every thing gaskets, trim and glass. I was told that they would be at my house on Monday between 10:00 and 2:00 to install it. Monday at 1:50 I call them to see were they are at and twenty minutes later the installer shows up.
The installer gets his glass out and I ask does he have evrything. He says yep windsheild and gasket. I ask about the trim and he said they don't carry that. He didn't have the back glass or gasket either. He said he could get the gasket for the trim but he cant get the trim. He said the gasket, trim and glass all had to be installed at the same time. With that piece of info, I told him I would wait until I got the trim.
My question is, does it all have to be installed at the same time? Should I get another installer? Or should I get a set of aviator glases and go without the windshield?
Franks69 is offline   Reply With Quote
Old 02-19-2013, 10:17 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Windshield Install ?
Trim goes into the rubber, before you can install the glass.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 02-19-2013, 10:43 PM   #3
Franks69
Thanks turp.The installer seamed on top of it,but after the run-a-round with the phone calls,I figured a second opion wouldn't hurt nothing. I appreciate it......THANK YOU.
Old 02-20-2013, 06:47 AM   #4
JimKshortstep4x4
You may want to make sure that they have the right seal for the trim as there are two different sizes on the part that fits into the seal.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-21-2013, 06:36 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Try this thread before doing anything: http://67-72chevytrucks.com/vboard/s...d.php?t=484773
Old 02-21-2013, 09:09 PM   #6
Franks69
Thats alot of good information. I'm giong to try to find the oem gasket. I hope I didn't toss it in the trash. I have the oem trim but its dinged up a bit. I don't know if it can be straighten out.
THANKS DeadheadNM
Old 02-21-2013, 09:28 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
THANKS DeadheadNM
You bet and good luck. The OEM trim isn't too hard to scare up on the parts board if you need a new set.
