Old 02-20-2013, 12:05 PM   #1
70blackfish
HELP. ID this Transmission
I got this engine and trans, and have no ides what transmission this is.
thanks for any help..
anyone know what trans this is?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 02-20-2013, 12:09 PM   #2
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Re: HELP. ID this Transmission
i need to see the shape of the pan (bottom) then I can prob help with the id. also get some pictures of the side where all of the cables are.
is it aluminum, or cast iron?
first impression is an old powerglide
iron
another iron
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 02-20-2013, 01:29 PM   #3
geezer#99
geezer#99's Avatar
Cast iron powerglide. That adaptor from the tranny to the block is worth a few bucks.
100 to 150 bucks. Don't throw it away.
Old 02-20-2013, 10:18 PM   #4
Livrat
Member #1049
Livrat's Avatar
Geezer is correct.. if you take a wire brush to the top of the trans you will find the word "powerglide" cast into it
Livrat is offline   Reply With Quote
Old 02-21-2013, 01:24 AM   #5
70blackfish
Thank you,
Old 02-21-2013, 08:45 AM   #6
midniteblues
midniteblues's Avatar
I have a dumb question on this,
why does that pg need a adapter too bolt too a sbc?
Is that a b.o.p pg?
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 02-21-2013, 12:36 PM   #7
ChevyCruizer
17's too small
only those old pg had that adapter.
BOP is Buick Olds Pontiac. They had a different shape/bolt pattern
Is that a b.o.p pg?
