Old 02-20-2013, 03:15 PM   #1
99monte
Cheap Dash repair
The dash pad on my 77 has some cracks,beside replacing the whole thing are there any repairs that can be done to make it look better?
99monte is offline   Reply With Quote
Old 02-20-2013, 05:49 PM   #2
JAMESCHURCH13
JamesChurch13
JAMESCHURCH13's Avatar
Re: Cheap Dash repair
I got the 40 dollar carpet cover from Summit. I don't mind that look myself. However if you search there is a member who sells a cover you put on your self that looks factory. Good luck.
HG/FTW!!!
Current vehicle collection:
1968 Chevy C-10 SWB Fleet Side, 327ci, TH350 (MD)
1987 Chevy Dually Quad Cab, 427ci, TH400
2008 Buell XB12SS, 1203cc
2006 YZ450F Wheelie Machine!
1997 Suzuki Bandit 600cc
And the Wife has some cars I pay insurance on and use to transport the kids!(01' Grand Cherokee and 06' Pontiac Grand Prix)
JAMESCHURCH13 is offline   Reply With Quote
Old 02-20-2013, 06:54 PM   #3
Low87
been here longer than Liz
Low87's Avatar
I got a nice $10 carpet cover from rockauto. Wound up using about 5x the velcro supplied though, to make it stay right.
I've seen some how-tos on using spray foam & bondo to patch the cracks, then a spray paint product to coat that somewhat replicates the texture. I might try that in the future.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 02-20-2013, 11:29 PM   #4
JAMESCHURCH13
JamesChurch13
Was the ten dollar kit universal or for our trucks.
HG/FTW!!!
Old 02-20-2013, 11:32 PM   #5
JAMESCHURCH13
JamesChurch13
http://67-72chevytrucks.com/vboard/s...d.php?t=442458
HG/FTW!!!
Old 02-21-2013, 12:00 AM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Same dash. What's your budget?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-21-2013, 12:44 PM   #7
Low87
Low87's Avatar
For our trucks. Very nice fit too.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 02-21-2013, 03:21 PM   #8
Rubble
That looks good,what did you use?? I got about 4 that need the same treatment!!!
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 02-21-2013, 04:03 PM   #9
INSIDIOUS '86
I just spent $50 on vinyl and adhesive and cut and sewed it. Used some leftover bondo to fil in the cracks
Old 02-21-2013, 05:46 PM   #10
Rubble
Thanx,I am going to try that.Will do one of my work trucks,if it doesn't turn out good,no big deal!
Old 02-21-2013, 05:52 PM   #11
INSIDIOUS '86
Yah I just did a baseball stitch for everything since its real easy to do.
Old 02-21-2013, 07:47 PM   #12
fastnloud
fastnloud's Avatar
Do you have a link to the $10 carpet? Thanks.
fastnloud is offline   Reply With Quote
Old 02-21-2013, 07:50 PM   #13
fastnloud
fastnloud's Avatar
I've always wondered if stripping the dash pad down to the bare material and spraying it with something like bed liner, would look good? I've been thinking about trying it.
I don't see a reason why you would have to have a foam on the dash pad.
Old 02-21-2013, 07:55 PM   #14
68Timber
I know the pieces fit
68Timber's Avatar
I've never written up how I did mine, but plenty others have shared. The only thing I did that I'm not sure if I've seen here is use expanding foam in all the speaker grills. It is very easy to cut with sandpaper but what is left is very hard and light. I used 3M 4240 to fill in the cracks after cutting the curled up high spots off with a dremel and sanded it smooth when dry. Then I sprayed on a coat of bedliner from rattle-can. I still need to do the color coat, but it looks good. If you don't mind giving up dash speakers when you're rebuilding your dash pad, the expanding foam will give you a solid repair.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-22-2013, 12:20 PM   #15
Low87
Low87's Avatar
It was the Foss Fiber shown in the rockauto catalog. Just checked and everything there now is $24 & up. When I bought it last year it was $10 - that's why I bought it. Tacked it on to an order as a "why not?" deal.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 02-23-2013, 12:42 PM   #16
JGood
JGood's Avatar
Check out this link and in the interior section they have a video on how to fix a dash pad using a plastic adhesive type stuff and some flexible filler
JGood is offline   Reply With Quote
Old 02-23-2013, 12:44 PM   #17
JGood
JGood's Avatar
http://2min.powerblocktv.com/_mobile/
Here's the link again
Old 02-23-2013, 02:32 PM   #18
mrhino
do know how long mine will hold up but i used a can of fiberglass, some plastic body filler, one of the wife's plastic containers. rolled on some epoxy primer, and the sprayed a couple of sem color coat.
mrhino is offline   Reply With Quote
Old 02-23-2013, 09:40 PM   #19
zook
zook's Avatar
great job!
zook is offline   Reply With Quote
Old 02-23-2013, 11:21 PM   #20
broey
Square
broey's Avatar
a friend cut a v into the cracks on mine, fiberglassed and then used bondo to smooth it out and then re wrapped it. also shaved the defrost vents in the process. came out killer.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 02-23-2013, 11:37 PM   #21
mooseknuckles
mooseknuckles's Avatar
I did the same thing kinda....fiberglassed it, then bondo, and lots of block sanding...
mooseknuckles is offline   Reply With Quote
Old 02-24-2013, 09:37 AM   #22
mrhino
that looks good!
Old 02-24-2013, 11:58 AM   #23
bilfman
bilfman's Avatar
A quick and easy is a glue on cover from lmc worked pretty good on mine and was 15minute install.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 02-25-2013, 12:22 AM   #24
bigwheel15
bigwheel15's Avatar
Theres a thread on here of a guy who filled the cracks in his dash with expanding foam and sprayed it with a product called flex seal which can be had at any auto parts store or even walmart. It looked pretty good imo.
bigwheel15 is offline   Reply With Quote
