1970 GMC 5.3/4l60e swap
After building up a pretty nice 350 and tearing up a few transmissions, I wanted to continue building my truck to make it a nice driver. I wanted fuel economy, overdrive, fuel injection, and good power. So I did some research and came to the conclusion a 5.3 vortec would be my best bet. I purchased a 2000 5.3 and 4l60e with all the accessories, harness, computer, and fuse block for $900.
Re: 1970 GMC 5.3/4l60e swap
Sold my small block I have room for the new motor. The truck originally had a 250 straight six and I had the 350 in the six location. I am truing to do this on a tight budget so I wanted to keep the drive shaft the same length. So after some calculating, I made my own adapter plates to fit in the six towers and use the same drive shaft. After some cleaning and plates made I got the motor and trans in. Everything fit fine, and I didnt have to buy adapter plates or modify the drive shaft!
The pcm is shipped off to Wait4meperformance to get tuned, my racing innovation stainless headers are bought but on back order, and I have a high pressure inline fuel pump on the way. Hopefully I can get it plumbed in this weekend when I am home (going to college and can come home a few times a month to work on it).
I am modifying my harness myself, and I am going to move the battery to the drivers side because that is where the harness wants it and I can use the existing intake tube, plan on just adding a cone filter.
I should't have to much more to buy, other than trying to hunt down a power brake setup at a reasonable price. Attached is a spreadsheet of my cost thus far. Well I guess I can't upload spreadsheets.
engine and trans 900 Motormount bolts 5 motormounts 15 starter 35 Power steering box 50 0bd2 connector 2 intake gaskets 36 exhaust manifold bolts 3 torque converter bolt 6 headers 207 fuel pump 95 pcm tune 88 1442 |
I have got a lot of work done lately, I got the transmission cross member modified and got the engine wired and plumed. Brake booster in (thanks drew67) and power steering lines in. Headers in and I fired it up.
Looking nice! Where did you get those headers? that is a GREAT price!
I got the headers from racing innovations. They are excellent quality but did not come with collectors so I have to find some 2 1/2 that are not reduced to tie in with my exhaust.
Posted via Mobile Device |
Got the exhaust tied in today and drove it about 125 miles with no problems. Great power and 18 mpg! I love it so far.
Truck looks awesome. Like the swap.
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
67cheby
![]() Join Date: Sep 2008
Sweet, cant wait to do the LS swap myself !
What did you use for a battery tray since you had to move the battery to the drivers side?
#13 |
I just modified my old one to the drivers side.
#14 |
Need to clean up some wiring but it runs and drives great.
#15 |
Location: Sunny, Florida, some might call it South Alabama
What air intake is that? Or did you just fab something up?
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
#16 |
It is a cheap cold air intake for a silverado that is on ebay for like 60 bucks, but I picked it up on craigslist second hand.
#17 |
Looking great, beautiful truck! Looking for some options to swap myself
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059 Front/back Porterbuilt dropmember, Accuair, LS1/4L60e Chevrolet C20 -72 C20 to K10/20 conversion, LS power. |
#18 |
Great job.
I am planning on doing this swap myself. Going to be a while though, the budget is pretty much non-existent. Can you give more detail in the fuel system?
"Live, Love, Build cool s***" Jesse Chapman, 2013 ![]() My Truck.. http://67-72chevytrucks.com/vboard/s...d.php?t=567219 |
#19 |
I am using the stock tank with a inline fuel pump, used steel line and for connections used gates fuel injection hose with fuel injection clamps. I am using a return fuel system, which I just put a return port in my stock tank. Works great and is the cheapest way to go.
#20 | |
#21 |
![]() Join Date: Jul 2012
looks great!!!
#22 |
I used a walbro inline 255 pump,
#23 |
Very nice...loving this!
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#24 |
Stock intake cleaned up the look some.
#25 |
Just a update on the truck, filled the tank up and drove it easy and got 21 mpg! Love the swap.
