Key Cutting Machines?
Only have 1 ignition/door key, so to be safe, went to Home Depot to get a duplicate key made.
After looking at it funny for a while, the employee tried to match it to his machine and said the key is too small for the copier. In addition, most hardware stores use this model machine. Is there a specific machine that I can call around for, that can copy the key? |
Re: Key Cutting Machines?
If you have blanks any key cutter should be able to cut them. I work at a KW dealer and we cut keys for old semis and the newer ones alike with the same machine.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Find a locksmith, he'll be able to do it right.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
![]() Join Date: Mar 2011
Check with member LocDoc... he will surely know.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
I just had this done (see my build for the story of the kid who can't see straight). You just need a blank called "B10" that you can find on the internet. You can take it to any key cutter like Ace Hardware or Lowes. I don't shop at Home Depot bc they fund bad stuff.
You might even be able to get it cut at a hotel if you ask the maintenance guy real nice. they have key cutters that they might have kept back from the time before electronic keys. Edited to add that even walmart cuts keys. Might be able to get them to do it if you bring the blank.
Step by steps: Remove primer to reveal original paint Rebuild a carburetor See My Build - Cecilia! ![]() Some people are like slinkys. Not worth much but funny as heck when pushed down stairs. Last edited by FetchMeAPepsi; 02-20-2013 at 06:35 PM. |
#6 | |
![]() Quote:
sam |
Who Me?
Only use a locksmith for keys like this.. HD will not have blanks for it.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
So the problem is that they don't have the right blank, not the machine?
Thanks. |
#11 | |
If you can't find someone after too much looking and worst comes to worst you can send me your key and I'll cut two of 'em for you. I ordered a bunch of blanks after our local place ran out so I got some just sitting around.
Step by steps: Remove primer to reveal original paint Rebuild a carburetor See My Build - Cecilia! ![]() Some people are like slinkys. Not worth much but funny as heck when pushed down stairs. |
I stopped going to box stores and chain stores for keys. 50% of the time they are cut wrong, either don't work or you have to shimmy the key to find the sweet spot to turn it.
It's worth the few pennies to go to a locksmith and get them cut. |
#13 |
I think in this case it's the lack of the right key blank, AND the machine at Home Depot.
I watched them cut a new key for my house locks, and they load the blank into a small box--they have a couple of these boxes, for different applications--and stick the box in the machine, and it cuts the key. It's not like the old one with the guy running the key across the cutter. Our local feed store has the old cutter, and the right blanks for my truck and cars. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
#14 |
Last fall went to Ace Hardware with my key for 1966 Chev and for $.99 each I had 4 keys made. Old timer knew right away what it was and made them up with the key machine that you stick the key on one side and blank on the other and it cuts the new one without anyone touching anything. All four fit perfect with no problems. Four keys for a little over $5.00 with tax. Guess I was lucky?
#15 | |
![]() Join Date: Jun 2006
I was a locksmith, locksmith's have the right blank and the proper machine to cut them. Those automatic cutters are a joke and even the common house keys get cut wrong.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#16 |
![]() Join Date: Aug 2010
Long story short. Saved a buck or so and had a key made at Home Cheapo for my wife's Accord. Ignition switch geeked on first use and I ended up spending several hundred repairing the column before the car was usable again. Lesson learned: pay someone who has the proper equipment and knows what they are doing. End of story.
#17 |
Okay, I don't know why nobody has pointed this out, but all of those machines can make duplicates of master lock keys, which are smaller than the keys for our trucks. They can do it if they have the right blank.
It really doesn't matter who does it. If they screw it up, they have to either do it right, or give you a refund. Over the years, I've had several keys that were made wrong and had to be replaced. Never once have I ever had a problem getting them to either fix the problem or give me a refund. |
#18 |
I bought my blanks on Ebay and the took them to the local Napa - maybe a buck and a half to cut me a couple of spares...
64 Step Side - The Mistress |
#19 |
I had the exact same issue with HD. I had the blanks but they couldn't cut them. I ended up taking them to the ranch store in town and they cut them for free since I had my own blanks.
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
