Removing my dash...help lol
So I've pulled out all the bolts I can find, it moves a bit but it just won't let go. I don't think just hauling on it is a good idea until I found out what's holding it lol hence my question here. My goal was to take it out to make the body work a bit easier.
thanks! Posted via Mobile Device
Dan 1968 Longbed Stepside C10 |
Re: Removing my dash...help lol
If you are refering to the metal dash panel #6 here, it is welded to the body at the windshield with a lot of spot welds.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Ha! there is my problem its awfully deceiving that they put bolts lol what gives!
![]() Join Date: May 2012
are you talking about the dash pad or the complete dash?
During cab assembly the bolts are used to position the instrument panel then it is spot welded along the windshield lip. The assembly manual can give some more detail.
![]() Join Date: Aug 2010
I've heard of guys cutting along the dash pad line that is hidden and welding it back in there. Not too sure on that though.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
I didn't see any rust along side the dash. so I'll probably put the bolts back in and pretend I wasn't trying to take it off lol
Where can I get this assembly manual?
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
#9 | |
Just about anyone who sells Chevrolet truck parts will have a 67-72 factory assembly manual. Might even be able to find it on CD. Be forewarned it is not paginated and a pita to find anything in at first. However it has a lot of information for people willing to use it.
Here is the page specifying the 34 spotwelds for the instrument panel.
![]() Join Date: Aug 2008
IMO you don't want to take the steel dash out unless absolutely necessary. real pita. Classic parts sells the assembly manuals at a good price to begin with ($30), then there is a 10% discount if you use "stovebolt" promo code. When I started my current build, I thought about buying one but have parted several, restored one GMC, so I know how itgoes together after all.
Posted via Mobile Device |
17's too small
i have pulled a couple of "uncut" AC dashes from the junk yard. drilled out all of the spot welds with a cordless and then the 3 bolts on each side. It isnt that hard.
You might be suprised how much surface rust is between the dash and cab once you remove it. Someone on here has pictures. For a daily driver dont bother but if you are gonna restore it 100% then I would say yes pull it out.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
#13 |
#14 |
![]() Join Date: Mar 2011
You dont want to remove the steel dash----unless you Have to! I did it in my build and its not quick or real easy. I would not recommend drilling out the pinch welds (personally I wouldnt do anythng to possibly upset the way the windshield fits.)
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
