Old 02-21-2013, 12:43 AM   #1
7071Bluck
1991 Burb to lay out?
Tomorrow I am going to buy a 91 burban that is bagged and lays crossmember in front. It has drop spindles but what else can I do to make it lay once I put bigger tires on it. Its got 205/65r15 on it now and lays but once I put a taller tire ill want it to sit just as low?
7071Bluck is offline   Reply With Quote
Old 02-21-2013, 01:52 AM   #2
maxxxy
maxxxy's Avatar
Re: 1991 Burb to lay out?
The front is whats holding you from laying out. You can solve this by
A) a dropmember,
B) a "Z"
C) a sectioned crossmember.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 02-21-2013, 02:16 AM   #3
andrewmp6
He's right the front crossmember hangs down lower then the frame.A link for the dropmember http://www.porterbuiltfabrication.com/?p=11
andrewmp6 is offline   Reply With Quote
