Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 02-21-2013, 12:47 AM   #1
Corts60
Just here to tinker
Corts60's Avatar
Suburban side window gaskets
OK, I know that we've mentioned this several times but I cannot find the thread.
Where is a place that sells the side window gasket sets? I've seen the website but cannot remember which one it was.
HELP!
Old 02-21-2013, 02:34 AM   #2
RockTonka
RockTonka's Avatar
Re: Suburban side window gaskets
Got ours from Truck and Car Shop out of Orange,CA...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 02-21-2013, 02:45 AM   #3
oklahomaduner
oklahomaduner's Avatar
This is where we get our stuff from, great people to work with and they have everything!!!!
http://www.truckandcarshop.com/6072.html
Edit: You beat me to it!! I got distracted looking through their catalog...
1966 GMC Extended cab 1 1/4 ton 4x4
My build thread
1958 Chevy 1 ton dually flatbed
My Dad's build thread
1966 GMC Custom Trim Big Back Window W/351e
1966 (Not So) All Original Chevy Custom Trim Suburban
My Dad's Time-Killing Project Truck
oklahomaduner is offline   Reply With Quote
Old 02-21-2013, 03:45 AM   #4
oem4me
I just looked at their catalog and it appears they sell two types: A "replacement type" for $25 ea, and "original design" for $169 pr.
which did you get and have you inspected them or tried installing them yet?
Old 02-21-2013, 08:41 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I think steele rubber might be the company that makes/repros the originals??
Old 02-21-2013, 11:09 AM   #6
Corts60
Just here to tinker
Corts60's Avatar
Thanks guys! Rocktonka, does that kit have everything to completely rebuild the sliders? How did the quality look to you?
Old 02-23-2013, 10:31 PM   #7
rustyrodknocker
Do not get the replacement stuff. If its the stuff I received its off a roll. Requiring a joint at the mitered corner. Worse its oversized with a much thicker crosection.
rustyrodknocker is offline   Reply With Quote
Old 02-24-2013, 12:35 PM   #8
rossboss
rossboss's Avatar
Sad to say if you want to do it right it's going to cost you. I steer away from packaged kits because they tend to not fit right. I got my rubber gaskets from steele rubber and they weren't cheap but they are quality, but that's all you get. The glass run channel and the beltline have to be purchased seperatly. C.R.Laurence makes these products and they are also quality. The glass run is 10G96 and the beltline is YM372, the only change you have to make is on the vertical piece of beltline that slips into the small channel. The stainless bead has to be removed for it to fit properly. It's easily removed with a pair of needle nose pliers. The C.R. Laurence products can be purchased at your local glass contractors or supply outlet. You can also buy and view the pieces at Restoration Specialties online.
rossboss is offline   Reply With Quote
Old 02-24-2013, 01:42 PM   #9
65chevysub
65chevysub's Avatar
I got mine from Steele back in the 90's, but I think Bob's Truck Parts in Mesa, AZ has them as well. Not sure about Bob's quality, but I'm going to get my liftgate/tailgate w/strip from him eventually to see how they are.
65chevysub is offline   Reply With Quote
Old 02-28-2013, 10:03 PM   #10
Corts60
Just here to tinker
Corts60's Avatar
Care to comment on the quality? Does the kit include all of the parts to completely rebuild the sliding windows?
Old 03-01-2013, 01:09 AM   #11
RockTonka
RockTonka's Avatar
Oops, forgot I had posted that here. We haven't pulled them out of the bags yet to check them out. We believe that we ordered everything that we needed to replace ALL the seals/gaskets in the burb. Probably going to be a bit before we get around to that...I don't remember paying too much for what we got So we probably have the ill-fitting flavor.
My build thread
