Old 02-21-2013, 10:40 AM   #1
70CHEVYBB
70CHEVYBB's Avatar
big block oil pan
I need to buy a oil pan for my 70 1/2 ton. I need to know if the stock 7 or 8 qt big block pan will fit in my chassis?
70CHEVYBB is offline   Reply With Quote
Old 02-21-2013, 11:37 AM   #2
vidman
vidman's Avatar
Re: big block oil pan
My 402 with stock pan fit fine and my later 454 with stock pan also fit OK. My stock pans only hold 5 quarts
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 02-21-2013, 12:57 PM   #3
70CHEVYBB
70CHEVYBB's Avatar
The pan I am looking at is from a c-30 or bigger so the base of the pan is not square. It is a rectangle and would move it closer to the x member.
Old 02-21-2013, 01:42 PM   #4
68 Longbed Dan
Vidman, your stock 454 pan Holds 5 quarts? is that the standard?
Dan
1968 Longbed Stepside C10
68 Longbed Dan is offline   Reply With Quote
Old 02-21-2013, 02:04 PM   #5
70CHEVYBB
70CHEVYBB's Avatar
Yes 5 qts is standard. I just do not have a pan ( my pan was to rusty) and have found one local but its the 7 or 8 qt pan. I just wasn't sure how close to the x member it would be.
Old 02-21-2013, 05:00 PM   #6
68 Longbed Dan
My 454 is actually a repurposed natural gas water pump engine. To withstand the temps out here it had a 16qt pan on it with an external cooler so now I need to nab a pan as well.
Dan
Old 02-21-2013, 09:21 PM   #7
vidman
vidman's Avatar
I know all the other 7-8 quart pans that i have used on trucks fit the application. Maybe someone will chime in that can give you a yes or no. if my motor was in the truck I could at least give you some kind of measurment..
Old 02-21-2013, 10:51 PM   #8
70CHEVYBB
70CHEVYBB's Avatar
a pic woul;d be nice if someone had one. I amoing to look at the pan inthe morning so I will just have to take a chance.
Old 02-22-2013, 12:45 AM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have a big pan on my BB with no issues. If you are not in a hurry sometime this coming weekend I will go under and take some pics.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-22-2013, 01:28 PM   #10
cdowns
cdowns's Avatar
i would first go to the autoparts store or GM dealership and check the cost of a new replacement oilpan and matching oilpump pickup b4 goin junkyardin
