02-21-2013, 12:16 PM | #1 |
ls swap computer help!!!!
im doing a 6.0 swap in my 69 c10 .my question is i got my 6.0 (lq4) i got it with a harness and computer, the vehicle had a 4l80 and was 4wd. however my 69 c10 is going to be 2wd and i already have a 4l60e, do i need to get a diff computer or can the t-case be tuned out and what will i need to do to make the 4l60 work, or do i need to get a whole different computer, i dont wont it to set codes or think its a 4wd
#2 if i di get another computer, can i get a 5.3 computer that has the right trans and just reprogram it for the 6.0?? thanks for any feed back im just lost right now i hope i didnt get a bunch of stuff i cant use lol
69 c10 shortbed work in progress 2017 gmc sierra denali 2006 silverado iron 6.2/6l80 |
02-21-2013, 01:32 PM | #2 |
Re: ls swap computer help!!!!
You won't need another PCM, you can have the tune changed to accomodate the 4l60e, it will require a segment swap, which most tuners can handle. Your wiring harness will need to be slightly modified also, but it's nothing major. The 4x4 stuff can be removed and tuned out also.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-21-2013, 02:18 PM | #3 |
awsome man thanks for the quick reply that answered all my questions, im not worried anymore, thanks
02-22-2013, 09:26 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
are you doing anything to the LQ4? cam swap? hard tune?
if you are, get the 4l80e, the 4l60e wont live long behind the torque of that 6.0 if you add anything. if your going stock, then maybe if your easy on it a stock 4l60e will survive for a while
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-22-2013, 12:17 PM | #5 |
im really good friends with jake over at jakes performance, i could build a 4l60 to handle 600 hp, i want a 4l80 just need to find one for the right price you know. not quite sure want i wanna do with the 6.0, i ordered hp tuners, eventually i might do a cam, valve springs, maybe a pro charger.. my buddy has a sstb all stock with 4l80 built andhp tuned he is running in the mid 12's i would rather get a 4l80 like you said they are wayyy stronger plus i can buy one and sell my 4l60 get bck some loss before i blow it up lol
02-23-2013, 05:46 PM | #6 | |
meowMEOWmeowMEOW
04-16-2013, 01:07 AM | #7 |
I believe the tbss have the 4l65e. Little stronger than a 4l60 couple upgraded parts..
04-16-2013, 11:41 AM | #8 |
meowMEOWmeowMEOW
Unfortunately, I believe, that you believe...wrong.
4l70e was the stock tbss trans, and is mechanically related to the entire family of 700r4/4l60/4l65 transmissions but has an additional input speed sensor kinda like the 4l80es. The 65e was in a bunch of vehicles like the silverado ss, but not the TBSS
04-16-2013, 12:52 PM | #9 |
Truck and auto performance nut
From a TBSS owner......yes they all came with a 4L70e. However...there are guys swapping a 4L80e/4L85e into their TBSS's as an upgrade. Even heard of a 6L80e swap. With 4700+lbs to move and an LS2 on the other end...the 4L70e's still aren't strong enough in stock form to handle the power.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
