02-21-2013, 03:49 PM | #1 |
Square
Mustang II measurement help
I am looking for someone with a 55-59 truck who installed a mustang II front end bagged that lays rocker. I am wondering if the mustang style crossmember clears the ground or if it needs to be modified to lay all the way out. And yes I already know about the other crossmembers out there. I don't need advice on which one to buy. Just want to know if the standard mustang kit will lay out when bagged.
Thanks Posted via Mobile Device
Squarebody Syndicate |
02-21-2013, 06:29 PM | #2 | |
Re: Mustang II measurement help
Broey- You need to buy a Porterbuilt Dropmember for the 55-59 Chevrolet Trucks. On a serious note: There is a place out of Lweisville,Texas called "Hales Speed Shop" that has done a few of the 55-59 trucks laid out with the M2 crossmember. I am sure if you got in touch with them, they could help answer some of your questions. Don't have a contact number for ya, but I am sure you know how to Google. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
02-21-2013, 07:48 PM | #3 |
Square
Thanks Nate. I talked to del actually about hales and he said he thinks they cut the crossmember and then add to the top caps. I don't think I'm gonna go that route if that's wha it takes. So now I am measuring to see if a 73-87 rolling chassis will fit. That wa I could just nip alot of little things in the butt all at once. Get the auto trans, v8, power steering, rear axle and then just add a drop member and rear end to it. Not sure if it's possible yet though.
02-21-2013, 07:52 PM | #4 | |
02-21-2013, 07:59 PM | #5 |
67-72 parts collector,…
73-87 track width up front is going to be too wide.
I'd rather use a S10 chassis than a C10 chassis.
02-21-2013, 08:20 PM | #6 |
Square
I thought the s10 swap was more of a 49-54 body style. Or whatever. Because those trucks were a little smaller. I'm going to measure everything this weekend and go from there.
02-21-2013, 08:28 PM | #7 |
I have a buddy that WAS trying to put a 58-59 on a C10 chassis.
It was going to be ultra low static dropped. The front track width was too wide. Not sure what he is doing now. How about a 88-98 chassis? http://67-72chevytrucks.com/vboard/s...d.php?t=427550
02-21-2013, 08:29 PM | #8 |
02-21-2013, 08:37 PM | #9 |
http://www.e-zchassisswaps.com/1955.htm
77-90 Caprice chassis swap.
02-21-2013, 09:28 PM | #10 |
Square
thanks for all the info keith. I wonder if the PB narrowed control arms will help at all. the reason I am wanting to choose a c-10 is that I have at my disposal a 73 shortbed with brand new 350 crate and rebuilt trans already.
02-21-2013, 09:31 PM | #11 | |
02-21-2013, 09:44 PM | #12 |
Square
whats a touch?
02-21-2013, 09:44 PM | #13 |
Square
also, I plan on using some skinny bias plys
