Old 02-21-2013, 04:28 PM   #1
slowboy
slowboy's Avatar
bad throttle response
my '72 GMC TRUCK has very bad throttle response from dead stand still...just wondering if this could be because of bad remanufactured Quadrajet, or bad detent cable, or what...
slowboy is offline   Reply With Quote
Old 02-21-2013, 04:35 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: bad throttle response
How did it run or respond before the reman Q-Jet? Can you look into the top of the carb and see it squirt fuel when you open the throttle?
When you say detent cable do you mean the cable from the carb to the trans that controls down shifts? That would not likely have anything to do with performance from a dead stand still.
TBONE1964 is offline   Reply With Quote
Old 02-21-2013, 05:36 PM   #3
Longhorn 70
Longhorn 70's Avatar
look for stuck choke, faulty or weak accelerator pump, stuck secondaries, or linkage that doesn't open the throttle blades.
Any black smoke out the back or popping when you hit the gas?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-21-2013, 05:56 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Old accelerator pump rubber doesn't like ethanol.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-21-2013, 05:57 PM   #5
slowboy
slowboy's Avatar
ran fine before reman Quad...don't see any fuel squirt when I open throttle...yes...detent I mentioned was to tranns...choke seems to be ok...secondaries, I don't think have opened up since I put carb on...no black, or any other color smoke out the back...or popping
Old 02-21-2013, 06:01 PM   #6
cdowns
cdowns's Avatar
ran fine and you changed it why???
Old 02-21-2013, 06:05 PM   #7
slowboy
slowboy's Avatar
changed it because it was leaking gas all around it
Old 02-21-2013, 07:07 PM   #8
68gmsee
Active Member
68gmsee's Avatar
If you don't see gas squirting out when you activate the throttle, acclerator pump is not working right. Could be they installed it improperly or it could be float is maladjusted.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 02-22-2013, 07:03 AM   #9
slowboy
slowboy's Avatar
Thanks to 'ALL'...looks like I'm getting another chance to rebuild a Quadrajet for the 2nd time...
