Old 02-21-2013, 06:52 PM   #1
Howitzer
Bellhousing to Block Bolt Size/Length
Anyone know the bolt size and length for the transmission bellhousing to block bolts (6 of them) for a 1972 402?
Howitzer is offline   Reply With Quote
Old 02-21-2013, 08:43 PM   #2
JimKshortstep4x4
Re: Bellhousing to Block Bolt Size/Length
The factory bolts were 3/8-16 x 1 3/8 (not positive on the length).
Standard 1 1/2" long bolts will usually bottom out in the female threads so you may want to compensate with washers or cut them off if this happens.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
