![]() Join Date: Aug 2012
parts
rolling chassis LWB 6 lug 1972 frame with 1968 rear end and 1968 front suspension the rear end has new seals both sides. The front suspension has new ball joints installed. I was going to use but I went and bought a 1972 frame with disk brakes and 5 lug rear. That is why it rears 1972 6 lug. Frame is in good shape. There is a small bend on the frame on the nose about 10 inch fron the front
1972 3 speed granny transmission standard 75.00 1972 stell beel housing 75.00 1972 fly wheel 50.00 1967 poss traction rear end. 3.73 ratio 200.00 sold rolling chassis without tires and wheels LWB 500.00 1967 small window cab rain gutter is in bad shape on the pass side.The inside is in great shape. Needs cab cornors on L/R side. needs rockers. The floor is in good shape. 100.00 will send pictures if interested. 1971 -1972 front and rear bumper chrome. 50.00 each Last edited by gdavis; 03-25-2013 at 10:11 AM. Reason: prices too high |
Re: parts
Also a tail gate for a 1968 step side 100.00
Re: parts
What is the gear ratio of the rear end? Thanks
Moderator
![]() Join Date: May 2007
Re: parts
Is the frame SWB or LWB?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: parts
Re: parts
Ok great. It's the posi rear end I'm interested not the rolling chassis. Thanks.
Posted via Mobile Device |
Re: parts
The only way, I can tell what ratio the rear is to spin the tire. I made a mark on the tire and the yoke on the front of the rear end. The ratio is 3.75 to 1. If there is another way let me know.
Re: parts
Re: parts
Re: parts
It sounds like you have a 3.73 ratio. Another way to tell for sure is to remove the differential cover and read the stamp on the ring gear. For a ratio of 3.73 it would read 41/11. I've got 3.07 gears up front so it wouldnt work for me. Thanks for checking!
Re: parts
Does anyone have a set of 350 chev exhaust manifold. I will be willing to swap some of my parts for. Or buy out right.
Re: parts
If possible could I get pictures of the cab? Thanks
#13 |
Re: parts
here is the pic of the cab. The inside of the cab is in perfect shape. Around the wind shield is spotless. No rust at all. The floor is in good shape. The only damage is exterior.
#14 |
Re: parts
IfGdavis Homosassa, Florida u want to see more tell me what you want to look at and I will send them.
#15 |
Re: parts
The only other areas I worry about is the firewall and below the dash on the inside. My cab had rusted so bad the windshield wiper motor broke loose. There is also under the dash where the seams meet on either side. Thank you for the information. Brian
#16 |
Re: parts
Interested in the rear end how long can it be held until pick up if paid for
#17 |
Re: parts
What kind of shape is the tailgate in? Any pics?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#18 | |
Re: parts
#19 |
Re: parts
Interested in front bumper, driver quality, pics?
1972 C10 LWB Cheyenne Super ![]() God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" ........................__ ..........._______ |__\__ ..........|__(O)______(O)] |
#20 |
Re: parts
here r the pic of the cab again. hope they help.
#21 |
Re: parts
more cab pictures.
#22 |
Re: parts
needs some sand blasting and a little bondo
#23 |
Re: parts
front and rear bumper together or will sell seperate.
#24 |
Re: parts
pictures of the bumpers
#25 | |
Re: parts
3.73 pos traction 200.00 sold regular rear end 150.00 stock Last edited by gdavis; 03-25-2013 at 10:14 AM. |
