Old 02-21-2013, 10:01 PM   #1
6T7NCHVYC10
6T7NCHVYC10's Avatar
Shaved door handles
Does anyone have any advice on a good shaved door handle setup? I am new to the forum, and will be posting pics of my 67 short step I am in the process of building. I really would like to install a good door popper setup,but have not researched it enough to know what setup work's best. Any help on the change over would be great. Thank's
6T7NCHVYC10 is offline   Reply With Quote
Old 02-21-2013, 10:03 PM   #2
Billett
Billett's Avatar
Re: Shaved door handles
can't say on these trucks, but my s10 had AVS door poppers. I liked the brand enough, but I'll never have door poppers again. They make universal kits that might work with these trucks. I've never had the mechanism out of the door so I couldn't tell you for sure.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-21-2013, 10:10 PM   #3
6T7NCHVYC10
Thank's for the reply. I'll check them out
Old 02-21-2013, 10:12 PM   #4
Billett
Billett's Avatar
also the vendors on here sell good stuff. these might help you out
http://67-72chevytrucks.com/vboard/s...d.php?t=430460
http://www.67-72chevytrucks.com/vboa...d.php?t=462127
Will
2024 Toyota Sienna
Old 08-03-2013, 03:06 AM   #5
hwyix
How come you say that? Do they not work?
I just purchased a 72 blazer with shaved door handles and in operative door poppers. The PO jerry rigged a lot of the wiring and pulled out the alarm.
I need to install new door poppers and control unit. I am looking for good/bad
recommendations.
It is a little old climbing through the rear hatch to get in my blazer. hahaha
hwyix is offline   Reply With Quote
Old 08-03-2013, 09:23 AM   #6
Tinkermc
Well to the forum , I may still shave mine
Tinkermc is offline   Reply With Quote
Old 08-03-2013, 11:15 AM   #7
LONGHAIR
I have used Autolöc kits dozens of times. They have a lot of kits to pick from, as simple or sophisticated as you could want.
They work great, have great directions, strong solenoids, etc.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-03-2013, 11:24 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
I agree with autoloc and there is a guy on here and ebay (here is infanti designs) that sells really really nice pre-made pieces to shave the door handles, firewall, stake pockets, and gas filler cap holes.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-03-2013, 11:36 AM   #9
67c10rustbuket
67c10rustbuket's Avatar
I have also used Autoloc and Infanti filler plates. Most part failures are from poor installation. I had a door popper and a pull solenoid fail on a truck I bought. The popper failed because it was mounted at an upward angle while the door curvature was the opposite (95 Silverado) so the door was pushing up against the popper when closing and broke the rod. The solenoid was mounted in an awkward position where it was not pulling straight. When installed properly they should last a long time. Another thing is most people buy the cheaper basic kit with underpowered solenoids and wimpy poppers, They make some nice upgrades in the more expensive kits.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-03-2013, 11:38 AM   #10
67c10rustbuket
If you do shave your handles make sure to get the emergency cable operated popper for when your battery dies. Much cheaper than a new window and disable any power locks.
Dan <---(my name)
Old 08-03-2013, 11:47 AM   #11
hwyix
Since I have blazer it doesn't really ever lock up. You can always get through the hatch. haha. Only one side of my hatch latches. If you pull real hard it would open without key.
Autloc is the brand I should be buying. thx for that. Is there a model you recommend or how many lbs the solenoid should be?
Old 08-03-2013, 11:48 AM   #12
Infanti
www.infantimachine.com
Infanti's Avatar
If you need any filler panel I can help you with them.
Gerry
Manufacture of Filler Panels
Billet washers
Infanti is offline   Reply With Quote
